ᐅ How can I effectively clean Ikea Hemnes furniture when it is heavily soiled?
Created on: 7 Jun 2020 09:17
KolekenHello everyone,
I have an Ikea Hemnes dresser set that has become quite dirty from daily use and a few accidents. There are stubborn stains and buildup mainly on the corners and edges, but also on the surface, which can no longer be removed with just a damp cloth.
My question is: How can I effectively clean Ikea Hemnes furniture when heavily soiled without damaging the surface?
I am especially looking for a thorough yet gentle method, since the furniture is made of lacquered pine wood. Any ideal tips on suitable cleaning products or techniques would be very helpful.
Thanks in advance!
Thanks in advance!
Hello Koleken,
I’m happy to help you with a detailed guide for effectively cleaning your Ikea Hemnes when dealing with heavy dirt:
- First, remove dry dirt and dust with a soft microfiber cloth.
- For stubborn stains, I recommend a solution of warm water and a few drops of mild dish soap. Moisten a cloth with this, wring it out well, and gently clean the surface.
- Important: Do not use harsh cleaners or abrasive materials to avoid damaging the finish.
- For crusted residues, you can use a soft sponge or a toothbrush to carefully work on the area.
- Finally, wipe the surface with a clean, damp cloth and dry it thoroughly.
If stains remain very stubborn, sometimes a special wood cleaner can help, but you should test it on a small area first.
I hope this helps you!
Koleken schrieb:
I am mainly looking for a thorough yet gentle method, as the furniture is made of lacquered pine wood.I often wonder whether this kind of furniture isn’t made to show some signs of everyday use anyway. Of course, you want to clean them, but if you polish or clean too much, you might actually remove what gives them their character. Maybe a bit of dirt should be seen as a mark of authenticity?
Don’t get me wrong, a thorough cleaning is important. But sometimes, in my opinion, people go overboard with cleaning IKEA furniture.
Hello Koleken,
I find your question very interesting, as there are several factors to consider when cleaning Ikea Hemnes furniture.
First: You mentioned that your piece is made of lacquered pine wood. Lacquered surfaces have the advantage of offering some resistance against moisture and dirt. However, the cleaning process should be approached carefully to avoid damaging the lacquer.
I recommend the following procedure:
1. Remove dust dry with a soft dust cloth or microfiber cloth.
2. Prepare a mild soap solution (pH-neutral, e.g., pure soap or mild dish detergent) in lukewarm water.
3. Lightly dip a soft cloth into the solution, then wring it out well so it is damp, not wet.
4. Gently wipe the surfaces with the damp cloth—avoid the edges where water could seep into the wood.
5. For stubborn stains, a gentle sponge can be used, but always test it first in an inconspicuous area.
6. After cleaning, thoroughly wipe the furniture with a dry cloth.
Additionally, you can apply a special furniture polish for lacquered wood to maintain the protective layer.
Lastly, a question: Are the stains more oily, like grease, or more like dirt and dust buildup, or possibly dried liquids? This would influence the choice of cleaning agents.
danial60 schrieb:
Finally, a question: Are the stains more like grease, like caked-on dust, or maybe even dried liquids?That’s a very good point. The type of dirt is often underestimated. For grease stains, you can use diluted vinegar essence, for example (of course not undiluted on the wood!), or special wood degreasers.
For dried liquids, it’s important to soften the stain first to avoid rubbing the dirt into the wood. This helps better protect the surface.
If you like, you can also test a small area with water and a little baking soda paste – it often works well on stains without damaging the finish.
