ᐅ How do I remove limescale from Malm surfaces after water damage?
Created on: 7 Feb 2024 10:03
Nonudi
I recently discovered heavy limescale deposits and stains on a Malm surface (specifically on a sideboard from this series) following water damage. The surface is made of MDF with a special coating that is said to be sensitive to aggressive cleaning agents.
My question is: How can I effectively and gently remove limescale deposits or buildup from Malm surfaces? Are there any proven products or methods that protect the coating while removing the limescale marks?
It is important to me that the surface does not become dull or damaged, as I want to preserve the piece of furniture as much as possible.
Thanks in advance for your tips and experiences!
Nonudi
7 Feb 2024 18:22
Thanks for the responses so far!
The lime deposits have been there for a few weeks and seem to have settled permanently due to splash water.
@Joe52
Joe52 schrieb:
I once had a similar problem with a lacquered piece of furniture after water damage. What helped me somewhat was a mixture of lukewarm water and a few drops of dish soap, gently applied with a microfiber cloth.
That sounds reasonable and gentle. Do you have any ideas on how to deal with stubborn lime stains without damaging the material?
@anken
anken schrieb:
There are special cleaning products for sensitive furniture that dissolve lime without being corrosive – for example, cleaners with mild phosphoric acid or certified plastic cleaners.
Could you maybe mention some products or brands that have proven effective? That would be great.
blapau
7 Feb 2024 19:05
I would like to add that with matte lacquered surfaces, there is always a risk of dulling during cleaning if you scrub too hard or use the wrong cleaning products.
It is important to apply a furniture care product after cleaning to restore the shine and protect the surface.
When choosing a product, I recommend looking for manufacturers who specialize in coated or delicate surfaces, such as furniture polish with carnauba wax, which can be applied and buffed easily.
U
uslis47
8 Feb 2024 08:14
I often clean such surfaces with a mild furniture cleaner that also contains descaling agents but no acids.
Afterwards, it is recommended to treat the surface with a neutral care product for high-gloss lacquer. This restores the shine and protects against new dirt.
If limescale is very stubborn, you can gently work on it beforehand with a soft sponge and great care, but never rub too hard.
draleo
8 Feb 2024 09:36
Here are some precise notes on the topic:
- Malm surfaces are usually made of MDF with a melamine or lacquer coating, which is superficially sensitive to acids.
- Lime scale mainly consists of calcium carbonate, which is very difficult to remove without acid.
- Common household remedies like vinegar or citric acid are unsuitable due to the sensitivity of the lacquer.
Recommendation:
1. Carefully dissolve lime scale using a damp microfiber cloth and a mild, neutral cleaner.
2. If necessary, gently work the area with a soft sponge (no abrasive materials).
3. Afterwards, apply a furniture polish with conditioning agents to protect the surface from further damage.
Avoid aggressive descaling agents to preserve the lacquer layer over the long term.
Dustin
8 Feb 2024 10:15
Sometimes, dry talcum powder can also help, which you gently rub in with a cloth.
This can loosen lime particles and protects the surface from scratches.
Ramon4
8 Feb 2024 11:58
A small tip:
If you use a wax or polish product to care for the furniture, always test a small area first to ensure the finish of the varnish is compatible.
Specialty stores or manufacturers such as „Frosch Möbelpflege“ or „Dr. Schutz“ usually offer suitable products for sensitive surfaces.
