ᐅ How do I remove limescale from Malm surfaces after water damage?
Created on: 7 Feb 2024 10:03
Nonudi
I recently discovered heavy limescale deposits and stains on a Malm surface (specifically on a sideboard from this series) following water damage. The surface is made of MDF with a special coating that is said to be sensitive to aggressive cleaning agents.
My question is: How can I effectively and gently remove limescale deposits or buildup from Malm surfaces? Are there any proven products or methods that protect the coating while removing the limescale marks?
It is important to me that the surface does not become dull or damaged, as I want to preserve the piece of furniture as much as possible.
Thanks in advance for your tips and experiences!
Nonudi
8 Feb 2024 14:42
Great, thanks for all the helpful answers!
@draleo
draleo schrieb:
Recommendation: 1. Gently remove limescale with a damp microfiber cloth and a mild neutral cleaner. 2. If needed, work mechanically with a soft sponge. 3. Then apply furniture polish.
That’s how I will proceed. I’ll look for a suitable furniture care product and test it first on a hidden corner.
@Dustin
Dustin schrieb:
Sometimes dry talcum powder helps, gently rubbed in with the cloth.
That sounds interesting, I’ve never heard of that before. Thanks for sharing!
I’ll report back once I’ve tried it.
Joe52
9 Feb 2024 09:13
Glad to hear you already have an idea.
Maybe a small consolation: lime stains often fade gradually due to humidity and time if you don’t damage them mechanically.
Sure, it doesn’t look nice – but it’s usually gentler than scrubbing too much.
Good luck with the cleaning!
Nonudi
9 Feb 2024 20:47
Quick update: I started with lukewarm water and dish soap, then gently treated the lime scale spots with a soft sponge.
The surface has remained glossy so far, with no dull areas.
I also bought a furniture care product based on wax and will try it tomorrow to refresh the protection.
Thanks to everyone for the many tips and recommendations; they gave me a lot of confidence!
U
uslis47
10 Feb 2024 08:50
Thank you for sharing your progress!
The careful approach sounds just right.
Wishing you continued success – once the surface is restored, the piece of furniture could maintain its appearance for a long time.
