Good morning everyone, I have an Ikea Malm nightstand that has unfortunately developed some minor surface scratches from everyday use. I’m interested in how to best remove these scratches without damaging the surface or risking discoloration. The scratches are mostly light and on the light-colored veneered wood. Does anyone have experience with suitable methods or products for professionally repairing these superficial scratches? Thank you in advance for your tips!
Hello, superficial scratches on a veneered Malm nightstand can usually be removed quite effectively with specialized furniture care products. An important type of product is furniture polish or scratch removers, which typically work on a wax basis and fill in the surface. It is advisable to always test the product first on an inconspicuous area to ensure there is no discoloration. Additionally, it is recommended to use a soft cloth and work along the wood grain to avoid creating new scratches.
Hello rulohau, to remove the scratches as effectively as possible, it is first important to understand the exact condition of the surface. Usually, bedside tables made of MDF are covered with a thin veneer, which should not be sanded down, as this would expose the underlying material. I recommend the following approach: first, clean the surface thoroughly with a non-greasy cleaner to remove dirt and dust. Then, you can gently work in a mixture of walnut or olive oil – both contain natural waxes that can help conceal minor scratches. If that is not enough, I suggest using furniture wax or specialized repair sticks, which are also available in colors matching the light veneer. These sticks fill the scratches and help even out color differences. A common mistake is applying too much pressure, which can further damage the surface – so be gentle! What is important for this kind of surface: avoid using water, as the veneer can swell.
I like it when furniture shines again – and this little trick really worked wonders for my Malm: Simply apply some olive oil to a cloth, gently rub the surface, and then polish it off with a dry cloth. The oil essentially creates a protective layer and makes scratches almost disappear. ;-) Of course, it’s not a solution for deep scratches, but it’s really great for small blemishes!
dijan schrieb:
This little trick really worked wonders for me with Malm...While olive oil is natural, it can go rancid over time and leave a sticky surface. Therefore, it is better to use specialized furniture care products designed specifically to protect the surface and mask scratches. This is especially important for veneered furniture to prevent the oil from soaking into the veneer.
