ᐅ How can I effectively and gently clean matte IKEA Metod cabinet fronts?
Created on: 14 Jan 2024 16:07
Fiore
Fiore
14 Jan 2024 16:07
I have installed matte cabinet fronts from the Ikea Metod system in my kitchen, which I have been using for some time now. I am starting to notice that they no longer look as fresh, and I would like to clean them gently yet effectively without damaging the matte surface or making it glossy. I am especially interested in which cleaning agents (home remedies or specifically recommended products) and cleaning methods work best to remove grease stains, fingerprints, and other dirt from these matte fronts.
Also, are there any things I should definitely avoid to preserve the matte texture in the long term?
I look forward to your tips and experiences.
SUBEN60
14 Jan 2024 16:29
Hello Fiore,
Your question about gentle and effective cleaning of the matte Ikea Metod cabinet fronts is important, as matte surfaces can be sensitive to the wrong products and methods.
- It is recommended to use warm water with a mild dish soap, as it effectively removes grease without harsh chemicals. A soft microfiber cloth provides the necessary gentleness during cleaning.
- Avoid scrubbing sponges or cleaning agents with abrasive particles, as these can permanently damage the matte finish.
- For stubborn stains, diluted isopropyl alcohol can be used sparingly, but always test it first on an inconspicuous area.
- Never use cleaning products containing ammonia or strong solvents.
In the long term, after cleaning, you should dry the fronts with a dry microfiber cloth to prevent water spots, which are especially noticeable on matte surfaces.
If stains are very persistent, it is better to clean gently multiple times than to scrub hard daily.
Dilen
15 Jan 2024 09:13
To complement your good basic question, I’m adding some details on how to properly care for and clean matte Ikea Metod cabinet fronts:
- Cleaning solution: Mix a mild cleaner or dish soap in warm water (ratio about 1:100). Too high concentrations can dull the surface.
- Tools: It is important to use a soft, lint-free microfiber cloth or a non-abrasive sponge. Slightly dampen the cloth before wiping—do not make it dripping wet.
- Procedure: First remove coarse dirt with a damp cloth, then gently treat stains with circular motions.
- Drying is a key point! Matte surfaces quickly show water spots, so allowing them to dry can cause unwanted shine or marks.
What to avoid:
- No aggressive cleaning agents containing alcohol, ammonia, or harsh solvents (acetone or similar), as they can damage the coating.
- Wood oils or waxes are not suitable for these surfaces.
- Cleaning tools with high mechanical stress (abrasive sponges, brushes).
Another question: Are your fronts laminate or foil-covered? This matters for cleaning agents since foils react more sensitively than matte paints.
If you like, please specify the type of dirt (e.g., grease, paint, water spots), and I can provide more detailed advice on possible cleaning products.
Josefane
15 Jan 2024 12:44
SUBEN60 schrieb:
For stubborn stains, isopropanol (alcohol) diluted can be used, but only sparingly and after testing in an inconspicuous spot.
Interesting point. However, I have some concerns about using alcohol on matte surfaces, especially if they are painted. Some coatings can dissolve or at least become slightly dull when exposed to alcohol, which may cause unwanted discoloration or uneven gloss levels.
I think Fiore should be really cautious here and maybe start by removing all dirt with lukewarm water and a mild detergent – if that’s not enough, I’ve had good experience with special plastic cleaners for matte kitchen fronts that do not contain aggressive substances.
Another question: Was the surface described by Ikea as "matte lacquered" or "matte laminated"? That could be important to determine the best cleaning method.
