ᐅ How can I clean Ikea Metod kitchen countertops without leaving streaks?
Created on: 19 Mar 2023 08:17
V
VESNA-JO34
Hello everyone, after recently purchasing our Ikea Metod kitchen countertop, I’ve encountered a cleaning issue: despite careful cleaning, unsightly streaks often remain, which are especially noticeable on the white surface and somewhat detract from the otherwise clean appearance. I’m interested in how you manage to clean your Ikea Metod countertops with minimal streaks – what products, tools, and cleaning techniques have you found most effective? Any tips on products that work particularly well to avoid leaving smears would also be appreciated. Thank you in advance for your helpful responses!
Surela
19 Mar 2023 10:33
VESNA-JO34 schrieb:
Would you say that I should do anything differently when cleaning, or is it usually enough to just use the right cloth?
I think the cloth is crucial in combination with the appropriate cleaning agent, but there are also some additional details that can help:
- Don’t use too much cleaning solution, as this can leave residues.
- Avoid wiping in circular motions; instead, wipe in the direction of the countertop grain, if visible, to reduce streaks.
- Rinse the cloth regularly during cleaning to avoid spreading dirty water.
What kind of all-purpose cleaner are you using? Some leave residues that aren’t immediately visible.
V
VESNA-JO34
19 Mar 2023 10:52
My all-purpose cleaner is a standard commercial product, nothing special. I might consider using pH-neutral cleaners. Are there any products that are definitely unsuitable for laminate surfaces? I also don’t want to damage the countertop.
Charles
19 Mar 2023 11:11
VESNA-JO34 schrieb:
Are there any cleaning agents that are definitely unsuitable for such laminate surfaces?
Yes, strongly alkaline or acidic cleaners, abrasive agents, and solvent-based cleaners are absolutely to be avoided. Using vinegar or citric acid can also damage the surface and cause it to become dull.
For laminate, mild, pH-neutral cleaners such as soapy water or specialized laminate cleaners are the best choice. Often, warm water and a good microfiber cloth are sufficient.
One more tip: always use cold or lukewarm water, as hot water can damage the coating.
fiman
19 Mar 2023 11:23
Clean with warm water and a microfiber cloth, then immediately dry with a clean, dry microfiber cloth. Do not use detergent or any other cleaners if it is just ordinary dirt.
gojan7
19 Mar 2023 11:40
If you have stubborn stains, mix a little baking powder with water to make a paste, gently rub the stains with it, and immediately wipe off with a damp cloth. Then quickly polish with a dry cloth.
Ramon4
19 Mar 2023 14:17
I can confirm that careful drying helps a lot. Something that worked for me as well: After cleaning, open the windows or ensure good ventilation. If the air is not too humid, the board dries more evenly, preventing water marks or streaks on the surface.
Also, have you tried cleaning the countertop with distilled water? This avoids lime spots, which often cause residue.
