ᐅ How can I clean IKEA Metod glass cabinet doors without causing damage?
Created on: 23 Jan 2020 08:27
ERWIN
ERWIN
23 Jan 2020 08:27
Good morning everyone,
I have a question regarding the proper cleaning of the glass fronts on my IKEA Metod kitchen cabinets. Since these fronts are made of high-quality glass with a special coating, I want to avoid causing scratches, dull spots, or any damage by using inappropriate cleaning agents or methods.
I am looking for a carefully balanced procedure that effectively removes dirt, fingerprints, and grease without harming the glass or the coating. Additionally, I am interested in whether certain household remedies are recommended or if only specialized glass cleaners should be used, and how much pressure is safe when wiping.
Does anyone have experience or advice on how to clean these professionally and safely? Are there differences in care compared to regular glass surfaces?
Thank you in advance for your expert support!
korosu
23 Jan 2020 09:14
Simply use a microfiber cloth with a little glass cleaner; that is sufficient. Do not use harsh cleaning agents or abrasive materials, as they can damage the surfaces. After wiping, rinse with clean water to prevent residue buildup.
PLOMA
23 Jan 2020 15:56
Hello ERWIN,
Here is how I clean IKEA Metod glass fronts:
- First, I remove loose dust and dirt by dry wiping with a soft, clean microfiber cloth.
- For the actual cleaning, I use a mild glass cleaner solution that does not contain alcohol or ammonia, as these substances can damage the special surface coating.
- The cleaning cloth should be well wrung out but still damp. You should wipe gently in circular motions to avoid streaks or scratches.
- After that, I carefully wipe again with a second, dry microfiber cloth to remove any remaining moisture and residues.
- It is important not to use sponges, rough cloths, or chemical cleaners with aggressive solvents, as these can cause micro-scratches or dull spots.
One more tip: If greasy fingerprints are common, using a spray with a slight antistatic effect can help reduce dirt adhesion.
I’m curious: Have you ever cleaned the fronts with a special or regular glass cleaner? Did you notice any issues with the surface?
ERWIN
23 Jan 2020 20:02
PLOMA schrieb:
For the actual cleaning, I use a mild glass cleaner solution that contains no alcohol or ammonia, as these substances can damage the special surface coating.
That’s an important point, thanks for clarifying. Until now, I often used regular glass cleaner, which contained ammonia. I actually noticed that the panels appeared slightly cloudy after some time.
korosu schrieb:
After wiping, use clear water to rinse off residues to avoid deposits.
I suspect this is crucial as well, since residues can build up on the coating and cause long-term damage.
PLOMA, you mentioned the antistatic effect. Do you use special products for that or just regular household sprays? I don’t want the panels to look overly shiny or artificial, but rather to preserve the natural glass appearance.
Does anyone have experience with home remedies like vinegar-water mixtures or similar?
gadalu
24 Jan 2020 11:37
For cleaning IKEA Metod glass fronts, I recommend the following procedure based on material and surface analyses:
- The fronts are made of safety glass with a protective coating that is sensitive to mechanical stress and chemical exposure.
- Therefore, abrasive cleaners, alcohol-based, and ammonia-based products should be avoided, as they can damage the coating.
- A pH-neutral, mild glass cleaning solution or lukewarm water with a drop of mild dish soap is ideal.
- Clean only with soft microfiber cloths—no sponges or coarse rags.
- Apply the cleaning solution to the cloth, not directly onto the glass, to prevent liquid damage at the edges.
- After cleaning, wipe again with clear water to remove any cleaner residue.
- Fingerprints can be removed particularly well with a slightly dampened microfiber cloth.
- For stubborn stains, gently soak the glass front by placing a cloth with cleaning solution on it, then carefully wipe it off.
- Regular and gentle maintenance is important to preserve the transparent shine and protective film over time.
In summary, avoiding aggressive chemicals and using a careful, mechanically gentle approach are key to maintaining the surface quality.
