ᐅ How do I clean heavily soiled IKEA Metod glass cabinet doors?
Created on: 10 Jan 2024 09:27
lododu
lododu
10 Jan 2024 09:27
Hello everyone, I have a question about cleaning my Ikea Metod kitchen cabinet doors with glass panels. Over time, a significant amount of dirt has built up that cannot be removed satisfactorily with regular cleaning agents and a damp cloth. This includes grease, fingerprints, and some sticky spots, likely from cooking splashes and frequently used areas. I am looking for a method that is effective but does not damage the glass or discolor the frames. Are there any proven cleaning products or techniques that work particularly well for this type of dirt? I would prefer to avoid sanding the doors or using harsh chemicals. Thanks in advance for any helpful advice!
mabla
10 Jan 2024 09:48
I would start with warm water and a few drops of dish soap. Then, polish with a microfiber cloth. For tougher grease stains, a commercial glass cleaner can also help, but use it sparingly.
Kinbu
10 Jan 2024 10:13
Hello lododu, for heavy dirt on Ikea Metod glass fronts, I recommend not removing the dirt mechanically at first to avoid scratches. A proven home remedy is a mixture of warm water with a splash of vinegar essence or lemon juice; this degreases well and does not damage the glass edges. It is important to use a soft, lint-free cloth (microfiber) and avoid rubbing too hard. If this is not sufficient, you can use special glass cleaners that are best suited for delicate surfaces and do not contain abrasive particles. After cleaning, be sure to wipe again with clear water and polish dry to prevent streaks or residues.
KAULIS
10 Jan 2024 11:02
For clarification: Ikea Metod glass fronts are usually made of safety glass, which is relatively durable, but the frame can be made of MDF or painted material, which may be damaged by harsh cleaners. Therefore, I recommend the following procedure for heavy dirt:
- First, remove dry dust or coarse dirt with a soft dust cloth
- Use a degreaser based on mild surfactants, for example, dish soap in warm water
- For sticky spots, isopropanol (rubbing alcohol) on a soft cloth can help, but the glass should not become too wet
- Avoid abrasive cleaners, ammonia, or strong alkalis, as these can damage the frame and the glass
- After cleaning, wipe with clear water and dry thoroughly
These guidelines are based on product information for safety glass and materials used by Ikea for their fronts.
lododu
11 Jan 2024 08:37
KAULIS schrieb:
For sticky spots, isopropanol (rubbing alcohol) on a soft cloth can help, but the glass shouldn’t get too wet
That sounds interesting, thanks KAULIS. Do I need to pay attention to specific concentrations? And are there any negative effects if I use it too often? Sometimes I worry that residues might build up on the frames or that the surface could become dull.
Joshbe
11 Jan 2024 09:10
lododu schrieb:
Do I need to pay attention to specific concentrations? And are there negative effects if I use it too often?
Isopropanol is typically used in concentrations between 70 and 90%. For cleaning glass surfaces, 70% is usually sufficient, but higher concentrations are not problematic as long as you use it sparingly. To avoid damage, moisten the cloth well and do not spray excess solution directly onto the glass. Frequent use can dry out the paint on the frame or the seal, so apply it spot-wise when possible and wipe afterwards with clean water to minimize residues.
