ᐅ How do I clean non-IKEA materials in an IKEA Metod kitchen?
Created on: 10 Sep 2022 08:43
janicleo
janicleo
10 Sep 2022 08:43
Good morning everyone, I have a specific question about cleaning IKEA Metod kitchens that include non-Metod materials. My kitchen consists not only of the standard Metod units but also mineral composite countertops, some glass fronts, and handles made of stainless steel and plastic. I’m quite unsure how to effectively yet gently clean all these different materials without damaging surfaces or affecting any sealants.
I’m particularly interested in suitable cleaning agents and techniques recommended for the combination of Metod components with these non-Metod materials. Are there any experiences or tips on how to remove limescale from the mineral composite countertops without causing etching? Which cleaners work best for the stainless steel handles to keep their shine? I also want to get the glass fronts spotless without streaks.
It would be great if you could share your advice for the care and cleaning of the various components in a Metod kitchen combined with non-Metod materials, ideally with guidance on proper application and what to avoid. Thanks in advance!
Kenon70
10 Sep 2022 09:12
Mineral composite surfaces are best cleaned with a mild detergent and a soft cloth. You can remove limescale stains using a vinegar-water mixture, but do not let it sit for too long. Treat stainless steel handles with stainless steel cleaner to maintain their shine. For glass fronts, simply polish with glass cleaner and newspaper for a nice streak-free finish.
kibutar
10 Sep 2022 10:53
Your question addresses an area I have been researching for years: the combination of IKEA Metod components with external materials often causes uncertainties due to differing surface chemistries. Here is a detailed cleaning procedure that I highly recommend:
- Solid surface material: Use only pH-neutral cleaners, ideally soap-based, to avoid damaging the surface. For common lime scale stains, treat them with vinegar water at a maximum concentration of 5%, applied briefly and rinsed off immediately. Important: Do not use abrasive cleaners or strong acids, as they can dull the surface or make it porous.
- Stainless steel handles: I recommend regular cleaning with special stainless steel care products (available at household goods stores). They remove fingerprints and protect against corrosion. A microfiber cloth works best.
- Glass fronts: It is important not to use cleaners containing ammonia, as they can damage glass edges. A commercial glass cleaner or a mixture of water and alcohol works well, preferably applied with a lint-free microfiber cloth.
After cleaning, it is crucial to thoroughly dry all surfaces to prevent water spots. I would like to know which exact external materials you have, as this can significantly affect the recommendations.
janicleo
10 Sep 2022 12:17
kibutar schrieb:
I would like to know exactly which foreign materials you still have – that sometimes significantly affects the recommendations.
Thank you for the detailed reply and the follow-up question! To clarify: the countertop is made of quartz composite, the fronts are average coated glass, the handles are stainless steel, and for joining materials I also have edge trims made of PVC. Additionally, there are silicone seals in some places that I want to keep clean. Are there any special precautions for these? I am particularly uncertain about quartz composite, as it is said to be sensitive to heat and acids.
Emery
10 Sep 2022 14:02
Quartz composite is actually sensitive to aggressive acids and heat. For cleaning, you should use only mild, pH-neutral cleaning agents and avoid abrasive cleaners. Limescale stains are best treated with a vinegar-water mixture, but never use pure vinegar or highly concentrated acids, as these can damage the binders.
For PVC edges, a damp cloth with some mild dish soap often helps; avoid aggressive solvents or strong alcohols, as these can fade or soften the material. Silicone joints are best cleaned with a soft sponge and a mild cleaner; usually, hand pressure is enough. Avoid sharp tools to prevent causing any cracks.
FLONE41
10 Sep 2022 16:45
I know that cleaning kitchens with mixed materials can be really frustrating, especially when you’re worried about damaging something. I had a similar experience with my Metod kitchen, where I also used different materials.
janicleo schrieb:
Which cleaners are best suited for stainless steel handles to keep their shine?
In my experience, simple cleaning with warm water and a microfiber cloth is often enough. I only use stainless steel care products as a supplement when the handles actually look dull or fingerprints are particularly noticeable.
Don’t worry too much—gentle cleaning and proper care usually preserve the materials for a long time. And if something does go wrong, with sensitivity and patience you can often restore it.
