ᐅ How do I clean non-IKEA materials in an IKEA Metod kitchen?
Created on: 10 Sep 2022 08:43
janicleo
Good morning everyone, I have a specific question about cleaning IKEA Metod kitchens that include non-Metod materials. My kitchen consists not only of the standard Metod units but also mineral composite countertops, some glass fronts, and handles made of stainless steel and plastic. I’m quite unsure how to effectively yet gently clean all these different materials without damaging surfaces or affecting any sealants.
I’m particularly interested in suitable cleaning agents and techniques recommended for the combination of Metod components with these non-Metod materials. Are there any experiences or tips on how to remove limescale from the mineral composite countertops without causing etching? Which cleaners work best for the stainless steel handles to keep their shine? I also want to get the glass fronts spotless without streaks.
It would be great if you could share your advice for the care and cleaning of the various components in a Metod kitchen combined with non-Metod materials, ideally with guidance on proper application and what to avoid. Thanks in advance!
PLOMA
11 Sep 2022 09:38
I would like to take a closer look at cleaning silicone joints, as this is often an underestimated issue. Silicone tends to attract dirt and mold quickly if it stays damp in the kitchen and is not properly maintained.
Here is my approach:
- Regularly clean silicone joints with a mild soapy solution and a soft sponge, as Emery already mentioned.
- Avoid abrasive or corrosive cleaners, as they can damage the silicone surface.
- For stubborn stains or minor mold spots, a 3% hydrogen peroxide (H2O2) solution helps. Apply it, let it sit briefly, then rinse thoroughly.
- Allow to dry completely afterward to prevent any remaining moisture.
If the silicone joints are porous or heavily soiled, I recommend replacing them, as cleaning will only be partially effective in such cases.
Surela
11 Sep 2022 14:47
I would like to add some information about cleaning glass facades, as this is often done with the wrong products.
- For coated glass, avoid harsh cleaners that may contain solvents or ammonia, as these can cause the coating to age prematurely or become dull.
- A simple cleaner made from distilled water and a small amount of isopropyl alcohol in a 4:1 ratio provides streak-free glass surfaces.
- The cloth used is very important: microfiber cloths are ideal because they don’t leave lint and won’t scratch the glass.
- For daily maintenance, often just a damp cloth without any cleaning agents is enough to remove dust and grease.
In short: less is more, especially when it comes to the aggressiveness of the cleaning products.
Kenon70
12 Sep 2022 08:29
Summary for Janicleo: Clean mineral composite with a mild cleaner and water; do not leave vinegar on it for too long. Use a special cleaner for stainless steel. Clean glass with an alcohol-water mixture, preferably using a microfiber cloth. Clean PVC and silicone only with mild cleaners. This way, you won’t damage anything.
janicleo
12 Sep 2022 10:04
kibutar schrieb:
I would like to know exactly which external materials you still have – this often significantly influences the recommendations.
Hello everyone, based on your great tips, I’m summarizing what I consider important: be careful with vinegar on quartz composite and solid surface materials, use special cleaners for stainless steel, and treat silicone seals gently.
Does anyone have experience with the long-term effects of the recommended cleaning products? I am especially interested in whether regular cleaning with alcohol- or vinegar-based solutions could be harmful when the kitchen is used and maintained daily. I want to avoid damage from overly aggressive cleaning, but still keep it hygienically excellent.
Thanks in advance for any feedback!
