miloslavbu18 Nov 2021 09:23Good morning everyone,
I’m currently considering whether it makes sense to secure IKEA Kallax shelves with silicone seals. Specifically, I mean sealing or reinforcing the joints between the individual units or between the shelf and the wall with silicone. My thought is that this could improve stability and prevent the shelf from sliding. On the other hand, I wonder if silicone might cause problems, for example during assembly, later disassembly, or due to the expansion and contraction of the material.
Has anyone had experience with whether “Kallax secured with silicone seals” is really effective, or if it’s more of an unnecessary or even harmful extra effort? What about the durability and flexibility of these solutions? Looking forward to your opinions and tips.
Thanks!
Thanks!
miloslavbu schrieb:
whether it makes sense to seal IKEA Kallax shelves with silicone jointsInteresting approach, but I think the question is almost philosophical. Silicone sealing on a piece of furniture? That sounds like sealing a ship. Is the shelf really that unstable? The material of Kallax is sturdy—at least if assembled correctly.
In my opinion, silicone here is more of a cosmetic measure that doesn’t really add stability, but definitely lowers the resale value significantly because it’s not easy to remove. Also, if you use silicone, it becomes harder to access the inside later or modify the shelf.
So I think you should carefully consider whether it’s better to keep a functional piece of furniture simple and, if needed, reinforce it with brackets or screws.
I would like to agree with LIELCHEN that silicone does not fundamentally improve stability.
However, there are situations where slight movements of a Kallax shelf unit can cause creaking noises or small gaps—especially when the shelf connects multiple modular components. Silicone could act as a dampener here and fill small cavities. But it should not be forgotten that silicone is elastic; it does not create a rigid, permanent bond between wood and wood.
From a technical perspective, it would be interesting to know whether the increased hold is measurable in the long term—I rather suspect not. Stability results from proper assembly and the use of additional fittings. Silicone could serve as a secondary measure, but not as a substitute.
LIELCHEN schrieb:
Silicone here is more of a cosmetic measure
warrenka5718 Nov 2021 12:33Thanks for the interesting thread!
I secured my Kallax shelf to the wall myself using silicone, not to connect the individual units, but to prevent the risk of tipping over.
This way, I was able to stop the shelf from wobbling or shifting with minor vibrations (for example, when vacuuming the floor).
I see silicone as a useful addition when it comes to safety. However, for simply stabilizing the modules together, I also consider it unnecessary.
Perhaps silicone is more of a solution for specific situations, but certainly not the standard. Anyone worried about the shelf should definitely fix it firmly to the wall!
I would like to add a brief technical note: Silicone joints are generally elastic and serve as dampers, not stiffeners. Since Kallax shelves are built on main components made of chipboard with melamine-coated surfaces, silicone can adhere well and keep joints free of dust.
What should be considered: Silicone remains permanently elastic, so it is actually well suited to sealing gaps against dust or moisture. However, it does not replace mechanical fasteners when it comes to preventing slipping or tipping.
Anyone applying silicone as a "joint seal" should ensure the material is suitable for the respective surface and does not cause discoloration.
In summary: Silicone can fulfill an aesthetic and protective function, but it is not a substitute for screws or brackets when strength is required.
