ᐅ Who truly keeps dust away from the Kallax long-term?
Created on: 25 Oct 2022 14:02
HANNOGU62
Hello everyone, I have a somewhat more specific question that has been on my mind lately regarding my Kallax shelf: What or who really keeps dust away from the Kallax on a long-term basis? I’m not just talking about short-term solutions like dusting or simple dust cloths, but effective methods or products that can prevent dust from building up in the compartments or on the shelves over a longer period (weeks or months).
I understand that the Kallax is open and there is naturally some risk of dust, but I’m curious if anyone has had good experiences with covers, special inserts, films, or other practical technical aids. I’m especially interested in whether the effort involved is worth the results and how maintenance-intensive such solutions are in everyday use.
Looking forward to your tips, experiences, or even critical assessments on this topic!
Laukau5
25 Oct 2022 19:05
I would like to elaborate on this topic a bit more, as many important points have been raised but are not yet fully explored:
The question "Who can really keep dust out of the Kallax long-term?" is complex because dust is a natural, difficult-to-control phenomenon.
From a technical perspective, here is my complete approach:
1. Material choice: Plexiglass, acrylic, or glass work very well as a visible barrier. Missing original doors can be supplemented with DIY options. However, factors such as weight, stability, and precise fit are crucial.
2. Installation: The attachment should be secure and airtight; otherwise, dust will enter through gaps. This can be time-consuming and requires the right tools.
3. Alternative: Kallax offers inserts and boxes that can be used. Fabric boxes are aesthetically pleasing but allow dust to pass through. Hard plastic boxes or screw-top containers are better in this regard.
4. Room environment: Reduce dust throughout the entire room, for example by using air filters, keeping windows closed during the day, and regularly dusting with a damp cloth. This impacts the amount of dust settling in the shelves.
5. Cleaning: Completely dust-free is probably impossible, but the measures mentioned can greatly limit dust buildup.
I am still wondering how much time you realistically want to spend on installation and maintenance? This will help recommend the best system.
HANNOGU62
26 Oct 2022 08:32
Laukau5 schrieb:
I’m still wondering how much time you realistically want to spend on installation and maintenance?
Thank you for the detailed answer. Good question: The installation should not be too complicated, as I don’t have much DIY experience or tools. In everyday life, I prefer a solution that requires as little maintenance as possible, but quick basic cleaning (every few weeks) is feasible.
It is important that the concept really makes sense and significantly reduces the dust problem, especially in deep compartments.
naujon schrieb:
Using boxes/baskets: Dust is usually kept away when items are stored in closed containers.
That sounds practical to me as well, but most solutions look open or have loose lids. I would appreciate tips on which boxes really seal well.
naujon
26 Oct 2022 09:14
HANNOGU62 schrieb:
I would appreciate tips on which boxes seal really well.
Certainly! Boxes that seal well should be made of sturdy plastic and have form-fitting lids, preferably with snap locks or similar mechanisms. Often, storage containers from office or household product ranges work well, such as those from brands like Ikea (e.g., Samla boxes) or other manufacturers offering specialized lids.
Important:
- The material should be dustproof (smooth, without holes).
- The lid should fit tightly and leave no gaps.
One drawback is that these boxes can be a bit harder to access if you use them frequently.
It’s different when you combine boxes with textile lids featuring zippers, which are more sealed than open ones but not completely dustproof.
Brief summary:
- For maximum dust reduction, hard plastic boxes with tight-fitting lids are best.
- Acrylic covers protect visible stored items, but only if they close well.
GU-LAU60
26 Oct 2022 09:45
Kallax has suitable doors available as accessories. They are easy to install and keep dust out.
Josefane
26 Oct 2022 10:32
I would like to make a critical comment regarding the common belief that covers or boxes can completely keep dust out of the Kallax unit.
Dust is not a physical problem that can be fully solved by a barrier; it enters through the smallest gaps and is spread by air movement.
GU-LAU60 schrieb:
Kallax has suitable doors as accessories. Just install them, and dust is no longer an issue.
This statement is too absolute – doors help significantly, but they are often not completely airtight, especially in models designed for simple installation.
Furthermore, it is worth considering whether the effort invested in dust protection is worthwhile compared to the benefit. A weekly light cleaning might be more cost-effective than time-consuming modifications or purchases.
My recommendation: Accept dust as a natural part of furniture, counter it with regular, effective cleaning, and use closed boxes or cabinets for sensitive or fabric items.
FLONE41
26 Oct 2022 12:15
Josefane schrieb:
Dust is not a physical problem that can be completely solved by a barrier; it gets through the smallest gaps and is spread by air movement.
That is absolutely true, but in my experience, good coverings still make life much easier. If you don’t mind not achieving 100% cleanliness, using something like acrylic sheets or doors noticeably reduces the amount of dust getting in—which makes a big difference for me.
I believe the key is finding a practical compromise that doesn’t complicate daily life with excessive maintenance or renovations but still blocks most of the dust. 🙂
