ᐅ KALLAX used as a console in a narrow hallway – how do you attach the doors?
Created on: 19 Aug 2024 08:37
Leonau46
I have a question and hope to benefit from the community’s experience: I am planning to use an IKEA KALLAX as a console in my very narrow hallway. The available floor space is limited, but ideally, I want to attach doors to it to neatly store items like shoes, bags, and similar things behind them.
My specific question is: How do you attach doors to a KALLAX when it is placed in a tight corridor with little space for opening? Do you use special hinges, magnetic catches, or other clever solutions to prevent the doors from sticking out or getting in the way when walking past?
Any tips on attachment methods, door-opening mechanisms that work well in narrow hallways, or additional measures such as alternative handles or the use of sliding rails would be very much appreciated.
Thanks in advance for your advice!
gregto
19 Aug 2024 11:46
Hello Leonau46,
for the screw length when attaching to KALLAX, you should ideally choose screws that penetrate 15-20 mm (0.6-0.8 inches) into the carcass, depending on the overall thickness of the wood panels. If the screws are too long, they can damage the material on the opposite side; if too short, they will not provide sufficient durability.
Push-to-open mechanisms vary in quality, but branded products usually last several years without wear. It is important that no excessive force is applied.
In narrow hallways, I also recommend adjusting the doors lightly rather than setting them too tightly, so minimal force is needed to open them. This helps protect both the mechanism and the wood.
Palenar
19 Aug 2024 14:27
As an addition, I would like to discuss the technical impact of door hinges in a KALLAX setup.
The original IKEA hinges are usually designed for standard kitchen cabinets, which allow more space for the door to swing open. However, in narrow hallways, it can be practical to use special hinges with modified opening angles (e.g., 90° instead of 180°). These hinges are particularly sturdy and help prevent accidental bumps.
Installation tips:
- Pre-drilling is essential, especially on MDF-like surfaces of KALLAX
- Use a torque wrench to protect the material and ensure consistently even clamping force over time
- Magnets can be added on the inside of the door and the inner frame for better hold
Are there any mobile impact points in your hallway, such as doors or corners, that could put additional strain on the KALLAX door? If so, installing a sturdy impact guard is definitely recommended.
Leonau46
19 Aug 2024 15:02
Palenar schrieb:
Are there any movable edges in your hallway, such as doors or corners, that could put extra stress on the KALLAX door?
Good question! The hallway is actually narrow, and directly opposite the KALLAX unit is the front door, which could occasionally close against the KALLAX door.
Therefore, it’s important to me that the door stays firmly in place when closed and does not warp or come loose from minimal impacts.
Can you recommend how the door could be additionally protected or secured for this particular situation?
KLO-KA
19 Aug 2024 15:15
Magnetic door holders are the preferred solution here to prevent the door from opening when bumped. These can be discreetly installed on the inside and act like a type of door stop.
Additionally, felt pads can be attached to the door edge to absorb impacts.
gregto
20 Aug 2024 08:04
To improve stability in case of impacts, I recommend mounting the doors using recessed fittings and hinges with built-in soft-close dampers.
These dampers absorb shocks, prevent slamming, and maintain alignment even under frequent use.
For heavily used corridors, this is a worthwhile investment that increases durability.
pikin
20 Aug 2024 09:55
Another option often overlooked in narrow hallways is folding or bi-fold doors instead of traditional hinged doors.
These require almost no clearance space in front since they fold or collapse, making them especially space-saving. Installation is somewhat more complex but worthwhile if the hallway is very narrow and there is a risk that doors could obstruct movement when opened.
There are also special hinges with damped folding mechanisms to ensure smooth opening in limited spaces.
