ᐅ Kallax doors installed incorrectly – how to fix the mistakes?
Created on: 5 Jul 2022 18:12
Plotan
Plotan
5 Jul 2022 18:12
Hello everyone, I unfortunately installed the doors on my Kallax shelf incorrectly. Some of the screws are crooked, the doors stick, and don’t close properly. I carefully followed the assembly instructions, but certain parts seem tricky, especially when aligning the hinges and the pre-drilled holes. Is there a way to fix the incorrect installation without having to drill new holes? I’d prefer to avoid visible damage to the wood or finish. What are your best tips or experiences for realigning Kallax doors after installation errors?
Gino38
5 Jul 2022 18:56
Basically, the Kallax material is not very durable when it comes to new drill holes, so it’s best to make the most of existing holes and hinges. First, check if the hinges can be adjusted slightly – usually, they can be repositioned on the back side. If that’s not enough, you can use small wooden shims or dowels as filler material before drilling new holes. For screws that are misaligned, I recommend carefully loosening and realigning them. It’s important not to apply too much force to avoid damaging the material.
PAREL
5 Jul 2022 19:22
Hello Plotan, I can gladly provide you with a brief step-by-step guide that has helped me with similar issues:
1. Remove the door completely: loosen all screws so the door can be taken off freely.
2. Check old screw holes: if they are cracked or worn out, you can use wood filler to repair them.
3. Inspect the hinges: many Kallax doors have adjustable hinges that can be fine-tuned afterward. Try this option first.
4. Tools to assist: small wooden dowels or toothpicks dipped in glue can help fix damaged holes.
5. For larger problems: drill a new hole next to the old one with a drill, but not too close in order to avoid weakening the wood.
Patience and precise work are essential. Did you mount the doors using the original tools? That can also make a difference.
rickey
5 Jul 2022 20:01
PAREL schrieb:
Many Kallax doors have adjustable hinges that can be fine-tuned afterwards.
That’s true, I also had the problem that my doors didn’t close properly at first and were quite tight. Adjusting them made a big difference. I know how frustrating this can be, especially when you think you’ve done everything correctly. 🙂
Don’t get discouraged; with a bit of patience, you can often fix a lot!
V
vin_leo
5 Jul 2022 20:45
A loose screw can become a problem faster than you might think – with my Kallax doors, I often noticed that the screws gradually loosen due to frequent opening, causing the doors to hang unevenly. So if you take the doors off again, be sure to check if any screws are loose or if the hinges look bent or damaged. 😉
Otherwise, small wooden dowels are really the secret weapon when you need to make adjustments, and if the color doesn’t match, a drop of wood glue will do the trick. The color will blend in over time, so don’t worry! 🙂
GU-LAU60
5 Jul 2022 21:07
Remove the door from its hinges, loosen the screws, fill the holes with toothpicks and wood glue, let it dry, drill new holes, and reinsert the screws. Done.
