Some time ago, I purchased a kitchen countertop from the IKEA Metod system and am currently looking for a gentle and effective cleaning method. The countertop is made of laminated plastic, and the surface should be protected as much as possible since small scratches or discolorations can appear quickly if you’re not careful.
I am especially interested in:
- Which cleaning products are suitable for IKEA Metod countertops and which ones should definitely be avoided?
- What is the best cleaning method to remove stubborn dried-on dirt (e.g., grease splatters or tar residues) without damaging the surface?
- Are there any special care tips that can extend the lifespan of the countertop and make cleaning easier overall?
I look forward to your experiences and advice. Thanks in advance!
GUSTAVO5611 Aug 2020 09:21Hello pupure,
Regarding the cleaning of IKEA Metod countertops – specifically the laminate-coated versions – I can provide you with detailed information, as I professionally handle coated surfaces.
Basically, you should avoid using aggressive cleaners that contain solvents, chlorine, or ammonia. Such products can damage the surface, causing it to become dull or rough, which is particularly undesirable for laminate. So, stay away from strong bleach, abrasive cleaners, or highly alkaline substances.
Instead, I recommend the following cleaning routine:
- First, wipe the surface with a soft, damp cloth and warm water.
- For stubborn stains (such as dried-on grease splashes), a mild dishwashing detergent diluted with water works well. Let it sit for a short time before gently wiping.
- A particularly gentle and effective method for tougher residues is a mixture of water and a small amount of vinegar essence, applied with a microfiber cloth. Vinegar helps break down grease and limescale but usually does not harm laminate.
- For solid residues, carefully use a soft plastic scraper or a non-abrasive sponge. Please do not use steel wool or scratching sponges!
- Afterwards, dry the surface with a soft, lint-free cloth to avoid water spots.
It is also important not to leave the countertop wet for prolonged periods after cleaning. Laminate is sensitive to water at the edges, so wipe it dry promptly.
Regarding care:
- Avoid exposing the countertop to high heat (for example, placing a hot pot directly on it).
- Use cutting boards to prevent scratches while cutting.
- Regular cleaning prevents more stubborn dirt, which is harder to remove.
If you like, you can tell me the types of stains you encounter most often – then I can offer more specific advice.
Regarding care:
Great question, especially since IKEA Metod countertops are common in many homes and people often underestimate how delicate some surfaces can be!
I’ve had a Metod kitchen with laminate countertops for two years and usually just clean with warm water and a bit of dish soap. If something is stuck on, I soak it with warm soapy water and then gently wipe it off with a soft sponge.
For me, harsh scouring pads or strong detergents are an absolute no-go – they cause more damage than good!
My advice: always wipe spills right away with a damp cloth to prevent them from setting in. Patience really pays off 😊!
If you’re still looking for a very mild cleaner, I can also recommend vinegar water for tougher stains.
I’m curious if you find any special tricks – it’s great that this topic is getting such close attention!
GUSTAVO56 schrieb:
So stay away from strong bleaches, abrasives, or highly alkaline substances.I completely agree, but sometimes I wonder if most people are too afraid of cleaning products. Of course, you shouldn’t be too harsh, but some surfaces are surprisingly durable.
With IKEA Metod countertops, I also think that proper care mostly depends on how carefully you treat the surface in daily use. However, I seriously doubt that mild dish soap solutions alone are always enough when dealing with really stubborn residues.
Sure, vinegar water is good against limescale, but for tough grease stains, a somewhat stronger cleaner might be necessary—naturally without abrasives.
I’m more inclined to think that the fear of stronger cleaners is sometimes a bit exaggerated, as long as you use them methodically and carefully.
What do you think? Could being more attentive during cleaning be more beneficial than fearing minor surface risks?
