ᐅ What is the best way to care for Ikea Pax wood surfaces?
Created on: 14 Dec 2023 08:37
Saumin
Saumin
14 Dec 2023 08:37
I recently purchased cabinets from the Ikea Pax series with wood finishes. I understand that wood or wood surfaces require special care to prevent drying out, staining, or discoloration. My question is:
What is the best way to maintain Ikea Pax wood surfaces to keep them looking good and durable over time? Are there specific cleaning products recommended, or are solvent-free household remedies better? And what about mechanical care, such as wiping, polishing, or occasional oiling?
I would appreciate detailed tips, including any dos and don’ts if possible. Thanks in advance!
lubla
14 Dec 2023 10:22
For Ikea Pax wood surfaces, I recommend using only soft cloths for wiping. It is best to use lukewarm water with a little mild dish soap and avoid harsh cleaning agents. Always dry thoroughly after wiping to ensure no moisture remains.
SUBEN60
14 Dec 2023 11:47
Regarding the care of Ikea Pax wood surfaces, I can clarify the following:
- The surfaces are usually coated with a melamine or foil layer, which can be sensitive to solvents.
- Do not use abrasive cleaners or alcohol-based products, as these can damage the surface.
- Cleaning with a damp microfiber cloth and pH-neutral soap is ideal.
- For protection and maintenance, regular wiping is sufficient; oiling or waxing is not necessary and is not recommended by Ikea for this furniture.
In short: clean gently and keep dry; usually, nothing more is needed.
likuken
14 Dec 2023 13:19
Saumin schrieb:
Are there any special cleaning products recommended, or are solvent-free home remedies better?
In my opinion, maintenance is generally overrated, at least for furniture like the Ikea Pax, which is not made of solid wood. The surfaces are industrially coated and quite durable.
So why go to great lengths when simply wiping with lukewarm water is completely sufficient? Genuine home remedies or expensive oils are unnecessary and might do more harm than good.
Of course, this assumes there are no heavy stains, but for those, regular cleaners that can be lightly diluted work well.
U
uslis47
15 Dec 2023 09:03
I would like to take the opportunity to respond in more detail to Saumin’s question, as the care and maintenance of wood surfaces can be a sensitive matter.
The Ikea Pax wardrobes with wood-look finishes usually have a surface foil rather than real wood or solid wood. This means:
- Regular wiping with a soft, slightly damp cloth is sufficient for normal use.
- Avoid aggressive scrubbing to prevent damaging the surface.
- Direct contact with harsh chemicals, strong cleaners, or solvents should be avoided.
If you have stains from coffee, grease, or similar substances, you can use a mild dish soap solution—very sparingly—and be sure to wipe it off afterwards with clean water.
For real wood, one might use wood oil or wax, but this is not recommended for Pax wardrobes and could potentially damage or make the surface sticky.
For touch-ups: A care cloth designed for foils or plastic surfaces can occasionally be used to provide light protection against dust and dirt.
In summary: Gentle cleaning, dry wiping afterwards, no solvents, no oil. This is the simplest and safest method.
Curtis
15 Dec 2023 15:26
That’s true, but you shouldn’t assume that all Ikea Pax surfaces have the same level of durability. There are different types – melamine, laminate, painted finishes.
uslis47 schrieb:
Avoid heavy rubbing to prevent damaging the surface.
Exactly. In addition, moisture always poses a risk to wood surfaces. Especially when temperature and humidity fluctuate, moisture can get under the laminate or coating and cause blistering.
Therefore, I would recommend ventilating the cabinets well in the room and never leaving them wet. A common mistake is leaving a damp cloth on the surface for too long.
A really intensive after-treatment (oiling, waxing) doesn’t make sense on a coated surface. It might look nice temporarily, but there is a risk of damage.
