ᐅ How can I securely and neatly attach Ikea Metod kickboards for long-lasting results?
Created on: 15 Nov 2020 08:17
Nubesin
Hello everyone, I am planning to install the kickboards on my new Ikea Metod kitchen. I want to achieve both a clean appearance and long-lasting stability. The kickboard should not only hold securely but also be easy to remove later if repairs or cleaning are needed. Are there any practical methods or tools you would recommend? I have read that some use clips, while others use screws, but I am unsure how exactly this works and what is best suited to ensure both a firm hold and a neat installation. Your experience and tips would be very helpful.
REPITAR schrieb:
I also recommend, if possible, to briefly test the clips in their position before firmly screwing them in, so they can be removed more easily later.Absolutely, this brief trial phase helped me a lot as well to find the perfect position and avoid mistakes that would have been frustrating later.
Sometimes you really only learn what works best through trying it out.
Good morning,
I would like to conclude this topic with a brief step-by-step guide on how to securely and neatly install Ikea Metod baseboards:
1. Planning: Measure the length and mark the positions for the clips at approximately 45 cm (18 inches) intervals.
2. Cutting: Make precise miter cuts for corners to achieve a clean finish.
3. Preparation: Ensure the base cabinets have a level surface.
4. Securing clips: Screw the clips in place with suitable screws, avoiding over-tightening.
5. Attaching the baseboard: Press the baseboard gently into the clips until it locks securely.
6. Checking: Verify the fit and make adjustments if necessary.
7. Cleaning and maintenance: After installation, use a damp cloth to remove any glue residues or fingerprints.
One more tip: The Metod baseboards are designed for easy removal if needed. This makes future adjustments or cleaning simpler and helps maintain long-lasting use.
I hope this summarizes everything important clearly.
