ᐅ How can I securely and neatly attach Ikea Metod kickboards for long-lasting results?
Created on: 15 Nov 2020 08:17
Nubesin
Nubesin
15 Nov 2020 08:17
Hello everyone, I am planning to install the kickboards on my new Ikea Metod kitchen. I want to achieve both a clean appearance and long-lasting stability. The kickboard should not only hold securely but also be easy to remove later if repairs or cleaning are needed. Are there any practical methods or tools you would recommend? I have read that some use clips, while others use screws, but I am unsure how exactly this works and what is best suited to ensure both a firm hold and a neat installation. Your experience and tips would be very helpful.
taudi
15 Nov 2020 08:48
Hello Nubesin,
I can recommend a structured approach that I have often used with Ikea Metod baseboards:
- First, check if your substrate is really level; small unevenness can make later mounting difficult and cause the baseboards to look uneven.
- Metod baseboards are usually attached with special clips that are screwed into the base cabinet. Make sure to place the clips about 50cm (20 inches) apart to ensure the baseboard is securely fixed.
- When installing the baseboard, simply press it into the clips; this ensures a precise and clean appearance.
- If you want extra security, you can also fasten small screws at the corners or in concealed areas to prevent any shifting.
Tip: If you want to cut the baseboards neatly before installation, a miter saw or a well-sharpened handsaw blade works very well.
Also, avoid applying too much force to prevent the clips from breaking. With this method, you are usually on the safe side both visually and in terms of durability.
If you have any questions about the exact procedure, feel free to ask.
Tudogo
15 Nov 2020 09:05
Hello Nubesin,
I agree with taudi and would like to add the following: The Ikea Metod baseboards are designed specifically for easy installation. You can attach the clips to the base cabinets in advance, preferably at sturdy points and not too close to the edges.
It is important that the baseboards are aligned correctly so that they sit flush with the floor. In some areas, it makes sense to temporarily remove the baseboard and check the subfloor or floor underneath to see if any slight unevenness needs to be corrected.
A clean look can also be achieved by using clever corner connectors, which Ikea provides or sells separately. These prevent gaps at the joints and give a higher-quality appearance.
I hope this helps! If you have any questions about which clips to use or how to install them properly, I’m happy to assist.
Juansi50
15 Nov 2020 09:21
I usually attach my Metod baseboards using the original clips. Simply place the clips, fasten them, and snap the baseboard on. It holds firmly and looks neat. However, you should measure and adjust carefully beforehand to avoid unsightly gaps.
tolokau
15 Nov 2020 10:02
Additional information: When installing Metod baseboards, preparation is key. Here is a brief guide based on my experience:
1. Prepare the surface: Make sure the base cabinets are level and stable.
2. Use clips: The typical Ikea mounting clips are fixed to the bottom of the cabinet with small screws.
3. Observe spacing: Place clips every 40-50 cm (16-20 inches) to ensure the baseboard is securely held along its length.
4. Cut the baseboards: Precise measurements are important; miter cuts, especially at corners, ensure clean joints.
5. Installation: Press the baseboard onto the clips; a slight "click" indicates it is securely attached.
Tip: For uneven surfaces, a small piece of double-sided tape between the baseboard and the floor helps stabilize it without damaging the baseboard.
Also, after installation, do not use excessive force when removing the baseboard, as this may break the mounting. If removal is necessary, a flat plastic spatula works well for this purpose.
REPITAR
15 Nov 2020 10:30
I would like to point out that the Metod baseboards are a system designed for lightweight construction. Therefore, do not overtighten the clips, as they can easily break. It is also recommended to mount and dismount the baseboards once as a trial to determine the perfect fit.
If you are looking for a particularly durable attachment, you can additionally use small, hidden screws from the inside of the baseboard to screw into the cabinet. This is more time-consuming but provides extra stability.
Summary:
- Use clips as intended
- Maintain a spacing of 40-50cm (16-20 inches)
- Be careful when tightening the screws
- Optionally secure with concealed screws
I have had the best results with this method in kitchens that are used frequently or subject to heavy loads.
