ᐅ How do I attach Ikea Metod kickboards to unusual floor coverings?
Created on: 23 Sep 2024 08:17
nonkloHello everyone,
I am currently planning the installation of the Ikea Metod baseboards in my new kitchen but am facing a challenge due to a very unusual flooring type. It is a thermally insulated cork floor with a rather uneven surface and a flexible subfloor.
My main question is: How can I securely attach the Ikea Metod baseboards to such an unusual floor covering so that they hold permanently without causing any damage to the floor?
Standard nails or screws don’t seem ideal here because the floor is softer, and I want to avoid compromising the insulation layer. Are there any proven methods, special fasteners, or alternative solutions you could recommend?
I would greatly appreciate any tips on surface preparation, adapting the baseboards, or experiences with other soft or uneven floors. Thanks in advance!
Hello nonklo,
I find your question very clearly formulated, thank you for that. The main issue with cork flooring is that it is flexible and soft, which makes it easy to damage or indent when fastening. Additionally, the insulation material underneath can be sensitive to nails or screws.
I would recommend the following:
- Instead of nails or screws, use a strong construction adhesive suitable for flexible substrates. Hybrid adhesives based on MS polymer are ideal as they bond very well and remain elastic.
- Make sure to thoroughly clean the cork flooring beforehand and remove any dust to ensure optimal adhesion of the adhesive.
- If the baseboards are very long, you can additionally install small washers or spacer blocks on the wall to reduce pressure on the floor.
- Check the IKEA instructions, as they often provide clips for fastening – here it would be worth verifying whether the clips can be easily combined with the adhesive.
If you like, I can also give you tips on how to apply the adhesive optimally and position the baseboard correctly.
The challenge of fixing Metod baseboards to a cork floor with insulation lies in the combination of a soft substrate and the need for a permanent attachment without causing damage.
Some facts and recommended approaches:
- Cork floors are sensitive to pressure and can deform under load, so mechanical fasteners such as screws or nails are not ideal.
- Using mounting adhesives specially designed for flexible substrates, based on silane or MS polymer, is advisable.
- Before adhesive application, the surface must be grease-free, clean, and dry to avoid loss of adhesion.
- Ikea Metod baseboards often use clip systems, which require firm substrates and are not ideal on cork floors without additional measures.
Alternatively, a securing mounting on the wall could be done, for example with screws into the masonry or with specially insulated washers, while the baseboard itself is only glued to the floor. This way, you prevent load from affecting the cork.
In summary: avoid mechanical fasteners on the floor; prefer mounting adhesive combined with wall fixing.
I really enjoy creative problem-solving! For your cork flooring, I would start with a gentle approach: as mentioned, mounting adhesive is your best friend.
Another option is to place a few small wooden strips or thin plastic spacers behind the Metod strip, creating a sort of intermediate layer so nothing sticks directly to the floor – this way, you can easily compensate for any unevenness.
And hey, don’t worry if it’s not perfect right away; cork is quite forgiving. With a bit of patience and some small tricks, it will fit securely and look great! 😉
