ᐅ How do I assemble Ikea Metod tall cabinets to ensure they stand securely?
Created on: 24 Apr 2015 21:37
LyantraHello everyone,
I am about to install several Ikea Metod tall cabinets in my kitchen and want to make sure they are assembled for a safe and stable installation. I am especially interested in how to properly secure the cabinets to the wall, which mounting materials would be ideal, and if there are any special considerations regarding the alignment or adjustment of the feet. Additionally, I am wondering if it is advisable to use specific connecting fittings between the cabinets to prevent tipping or shifting.
Does anyone have practical experience or tips on assembling Metod tall cabinets to ensure they are particularly stable? I look forward to your advice!
Hello Lyantra,
make sure to secure the tall cabinets to the wall using the included wall brackets, as this is essential for stability. Adjust the feet so they are level to compensate for any unevenness.
If you have multiple cabinets placed side by side, connect them using the straps or screws provided by Ikea. This will make them more stable and prevent them from sliding.
Hello Lyantra,
I completely understand your question, as the safety of kitchen cabinets should always come first. Whether you are assembling one or several METOD tall cabinets, here are some important points I always keep in mind:
- Wall mounting is crucial: Always use the provided brackets and attach them directly to stable points in the wall, such as with anchors for concrete or solid masonry. For drywall, you need to use special cavity anchors.
- Adjust the feet so the cabinet is level to prevent any tipping.
- Connect multiple cabinets together using the screws from the assembly kit to eliminate any gaps between the individual units.
- Consider the load: tall cabinets, base cabinets, or wall cabinets should be secured appropriately depending on their weight.
- If you find anything unstable, you can also purchase and install additional brackets yourself.
I hope this helps! If you have any questions about specific cabinet types or your wall material, just let me know.
emmaju schrieb:
Wall mounting is keyExactly! If the cabinets aren’t secured to the wall, they tend to slide around like a “dance floor,” and nobody wants that in the kitchen 😉.
Here’s a little tip: when placing several tall cabinets side by side, be sure to screw them together using the connectors provided. This allows them to support each other and greatly increases stability.
One more thing: Ikea Metod legs can sometimes be a bit tricky. The trick is to first adjust all four to roughly the same height, then set the cabinet upright and check with a spirit level. After that, you can fine-tune them. That way, nothing wobbles.
Good luck with the assembly!
Lyantra schrieb:
how to properly attach the cabinets to the wall, and which mounting materials are best to useFor attachment: Heavy-duty wall anchors suitable for your masonry are recommended. Avoid universal anchors; if you have metal studs or drywall (plasterboard), use special hollow wall anchors designed for these.
Lyantra schrieb:
if there are any special considerations for leveling or adjusting the feetThe feet should be adjusted to ensure the cabinet stands level; use a spirit level. Turn the feet slowly in small increments, about a quarter turn, then check the level.
Lyantra schrieb:
whether it is advisable to use special connecting fittings to join the cabinets togetherDefinitely. The supplied connecting fittings significantly increase stability, especially when placing multiple tall cabinets side by side. Without connectors, the cabinets may shift or wobble under load.
In summary: good anchors, fixing to stable walls, and proper adjustment of the feet are key to a secure installation.
