ᐅ Securely Mounting Ikea Metod Wall Cabinets on Drywall and Concrete Walls
Created on: 16 Jul 2020 08:23
jack37
Hello everyone, I am planning to install Ikea Metod wall cabinets on my walls. The specific situation is that one wall is drywall (plasterboard), while the other is concrete. My question is how to securely fasten these wall cabinets to both drywall and concrete walls to ensure long-term stability and load-bearing capacity. I have read that with drywall, special attention must be paid to the substructure and appropriate anchors, while concrete requires different fixing methods. Could someone provide informed advice on which screws, anchors, or mounting systems are best suited for each case? Additionally, I am interested in any particular considerations for wall preparation or additional measures for load distribution when mounting heavy cabinets. Thanks in advance!
jack37
17 Jul 2020 07:34
Hello everyone, I have now purchased the materials and am about to start installation. I have chosen countersunk screws to attach the Metod wall cabinets to the wooden batten on the concrete wall. The wooden batten itself is fixed to the concrete wall with heavy-duty anchors.
My question: Is there a recommended sequence or technique for hanging the cabinets on the batten? I am considering either fully assembling the cabinets first and then simply screwing them to the batten, or hanging each cabinet individually on the batten and then assembling them together.
I want to minimize the effort needed for adjustment to ensure everything is straight and securely mounted.
taudi
17 Jul 2020 08:16
jack37 schrieb:
My question: Is there a proven order or technique for how to best hang cabinets on the batten?
I recommend first securely attaching the wooden batten horizontally and firmly to the concrete wall. Then you can hang each cabinet individually on the batten and fix it in place. This has the advantage that you can align and adjust each wall cabinet separately.
Later, when all cabinets are hanging side by side, you can connect them by screwing them together. This helps distribute the load more evenly and makes the entire structure more stable.
Additionally, mounting cabinets individually makes it easier to adjust height levels and spacing.
Always remember to use a spirit level and, if necessary, small shims to compensate for any unevenness in the batten surface.
PULAU
17 Jul 2020 10:22
jack37 schrieb:
I want to minimize the effort needed for adjustment so that everything is straight and securely fitted.
The advice from taudi is correct. Installing the units individually offers more flexibility during alignment. Additionally, before tightening the screws permanently, you should check whether the mounting holes in the strip precisely match the cabinet brackets. If not, it is advisable to slightly loosen the screws first, make the necessary adjustments, and then tighten them securely.
Furthermore, using spacer washers can help if unevenness in the cabinet or the strip makes installation difficult.
If you assemble the cabinets completely first and then install them, small differences in the gaps between cabinets may be harder to correct later. Based on my experience, it’s better to install them individually and then fasten them together.
jack37
18 Jul 2020 11:05
Thank you for your tips!
One last question regarding the drywall area: I will be attaching the Metod wall cabinets to the metal studs. Is there a recommended type of screw or recommended screw length? I already know that the metal studs are 0.6 mm thick, and the drywall is 12.5 mm (0.5 inches) thick.
Is a self-drilling metal stud screw about 35 mm (1.4 inches) long sufficient? Or should I use longer screws that go through the drywall and grip as deeply as possible into the stud?
I want to avoid any safety risks since the cabinets will need to hold a significant amount of weight.
gadalu
18 Jul 2020 14:46
jack37 schrieb:
Is there a recommended type of screw or a recommendation for screw length?
For fastening to 0.6 mm (0.02 inch) thick metal studs behind 12.5 mm (0.5 inch) drywall, I recommend self-drilling screws with a length of at least 35 to 40 mm (1.4 to 1.6 inches). The screws need to be long enough to pass through the drywall and the metal stud wall and provide sufficient grip.
The screw diameter is important: a common size is 3.9 x 35 mm (3/32 inch x 1.4 inches) for standard profile thicknesses, which offers good holding power without damaging the metal. The screw should not only penetrate the surface but also create a secure connection in the metal profile.
Use high-quality galvanized or stainless steel screws to prevent corrosion.
If you are mounting several heavy cabinets, it is advisable to check the load-bearing capacity and, if necessary, reinforce with a wooden framework or mounting rail.
Don’t forget to consider the load limit of the entire drywall assembly in your planning.
