ᐅ How do I install IKEA Metod kitchen cabinets with an integrated waste sorting system?
Created on: 13 Jun 2023 08:14
Parjoren
I am currently planning to install an IKEA Metod kitchen with an integrated waste system and am facing some challenges in assembling everything correctly and aligning it optimally with the waste system. Specifically, I would like to know how to build the versatile modules of the Metod kitchen units so that the waste system (especially the waste bin insert integrated into the base drawer) is installed securely and functions well.
Could you please explain in detail what points I should pay attention to—for example, when assembling the side panels, drawer slides, fastening the waste containers, and organizing the compartments? Are there any special tips, or did you find the installation more complicated than expected?
For context: this is a corner kitchen with several base units, including some with pull-out cabinets.
Thanks in advance for any input and shared experiences!
reni45
13 Jun 2023 13:16
It is best to carefully maintain the alignment of the guides. If there is any sticking, it is usually due to a small deviation during installation. Check and adjust the gap dimensions. Do not tighten anything too much before making adjustments.
PLOMA
14 Jun 2023 09:53
Hello Parjoren,
I am adding some technical details about installing the integrated waste system into the Metod base drawer, which are often overlooked:
- Check that the carcasses are exactly square before attaching the drawer slides. One method is to measure the angle at each corner.
- It is important that the rollers on the drawer runners run smoothly and are free of debris. Before installation, check that the running rails engage cleanly with the rollers.
- For the two-runner systems in the base drawer, it is common for the rear rail to be mounted slightly longer or deeper. This improves stability.
- Sometimes it is advisable to slightly increase the depth of the base drawer with small spacers if the waste system is very sturdy.
- Use only the screws specified by IKEA, especially for the drawer slides.
- Ensure that the waste system sits firmly and does not wobble; this can be adjusted with appropriate leveling feet or clamping strips.
Finally, a question: Are you using the waste system with a removal control mechanism for organic and residual waste, or do you have individual containers without a mechanism? This is relevant for the opening force required and the stability demands of the drawer.
Parjoren
14 Jun 2023 10:35
PLOMA schrieb:
Are you using the waste system with a dispensing control mechanism for organic and residual waste, or do you have individual containers without any mechanism?
Thank you for the detailed clarification. I use individual containers without any mechanism, which are simply hooked in and held in place by frame clips. My main concern is ensuring the secure fixing and alignment of the entire system within the bottom drawer, so that the containers don’t wobble or fall out when the drawer is pulled out.
You also mentioned stability. From your experience, how does the material of the drawer bases affect load capacity? Ikea offers chipboard in various thicknesses. Is the standard board sufficient, or would it be better to choose a more robust version, especially considering that the waste containers can become quite heavy?
tyson51
15 Jun 2023 07:21
In my experience, the standard particle board from IKEA is usually sufficient as long as the carcasses are well screwed together and the bottom drawer is evenly loaded.
However, if you frequently use heavy waste bins or have a lot of compostable waste that can be wet and heavy, a more robust board or reinforcements are definitely advisable.
Additionally, installing cross braces under the bottom can provide extra stability. Also, regularly check the drawer slides for wear when they are under maximum load.
TEOZAR
15 Jun 2023 08:03
tyson51 schrieb:
Also regularly check the drawer slides for wear under maximum load.
A very important point! Especially with waste disposal systems that are used daily and often subjected to wet or heavy residues, the tracks wear out faster. Regular maintenance, such as cleaning dirt and lightly oiling the mechanism, significantly extends their lifespan.
