ᐅ First Ikea Kitchen... Now with Backsplash (p. 7)
Created on: 22 Mar 2015 21:21
Coletrickle_7808
Hi dear community,
My girlfriend and I will soon be moving into a new apartment. Our current kitchen will stay in the apartment or alternatively be sold on eBay.
Since the prices for kitchens we like at various kitchen studios or furniture stores are simply too expensive, we will definitely buy the new kitchen from IKEA. We just can’t justify paying over €10,000 (about $11,000) just for the cabinets.
We have set a budget of around €7,000 (about $7,700), including appliances.
We have already purchased a Siemens oven with pyrolysis cleaning, a built-in Neff induction cooktop, and a freestanding Siemens stainless steel refrigerator. We will also get a dishwasher and a range hood, both from Siemens. Altogether, this brings us to about €3,100–3,300 (around $3,400–3,600). This leaves us with approximately €3,500 (about $3,850) for the cabinets. Initial planning suggests this should work.
First, I would like some advice about the cabinet fronts.
We generally like the country style but want to keep it somewhat modern, for example with the handles (Örrnas or VÄRDE). We like Bodbyn, Kroktorp, GRYTNÄS, and Laxarby.
Are there any general pros and cons of the mentioned fronts? Laxarby, for example, is significantly more expensive than GRYTNÄS. My girlfriend especially likes Bodbyn in gray, but I would prefer something lighter.
For the countertop, we want the 2.8cm (1.1 inch) oak wood slab, which matches our dining table perfectly.
Secondly, about the installation.
There are no stupid questions, but… is the assembly difficult? I would consider myself and my dad fairly handy.
The kitchen will basically be a single line along a wall about 4.00–4.50m (13–15 feet) long; I still need to measure exactly. I would like a small L-shape, but on the back wall this is hardly possible because the radiator starts after about 1.00m (3.3 feet). Since the kitchen is also open on the other side, I wanted to create a subtle L there. However, the online planner complains because this L-piece is not attached to the wall. Does it have to be placed against a wall… or how does it work?
For the fully integrated dishwasher, you definitely need that rail — the name escapes me!
The oven will go in a tall cabinet; is there anything specific to keep in mind here?
For the backsplash, I would like to use aluminum panels with printed images. These are available on various websites in 2mm (0.08 inch) thickness and should fit into the IKEA rails, right?
Any general advice and tips are very welcome.
To give a better idea, I can also post the floor plan or design as a picture.
Coletrickle_7808
6 Apr 2015 21:20
For practical reasons, I will now use a simple dishwasher front, not a split one.
Specifically, the fronts would look like this:
1. Tall cabinet with oven and 2 x 40cm (16 inches) drawers
2. Sink cabinet, also 2 x 40cm (16 inches) drawers
3. Dishwasher with an 80cm (32 inches) front
4. Cooktop with 40cm (16 inches) and 2 x 20cm (8 inches) fronts
5. Base cabinet with 40cm (16 inches) and 2 x 20cm (8 inches) fronts
6. Corner cabinet with 80cm (32 inches) front
This way, the 80cm (32 inches) fronts would frame the base cabinets with 3 fronts. I think this looks best visually.
Coletrickle_7808
2 May 2015 10:52
The kitchen will be ordered this month. I have a few questions.
The baseboard is exactly 8cm (3 inches) high. According to various videos, the wall rail should be installed precisely at about 82cm (32 inches) from the floor to the bottom edge. Before that, you should measure whether the floor is level to ensure the baseboard height of 8cm (3 inches) is consistent everywhere.
Would you recommend measuring and installing it exactly, or leaving a bit more space, for example 8.5cm (3.3 inches), to avoid having to shorten the baseboard later?
When using the wall rail system, the cabinet boxes are placed on the front legs only. For better stability, is it still possible to install legs at the back as well?
Am I correct in understanding that Ikea does not use wall trim strips, but rather regular side panels that you can cut to size and then simply attach with an angle bracket, for example to a tall cabinet?
IKEA-Experte
2 May 2015 16:14
I would actually start by determining the highest point of the floor. In my kitchen, the height varies by up to 3 cm (1.2 inches).
You can also use four legs (which I would recommend), but keep in mind that with the low plinth height, the legs are practically not adjustable from the front.
Do you mean the wall connection between the carcass and the wall? The side panels are sized so that with an ideally straight wall, they have exactly the right width. When they rest against the wall at the back, they align flush with the fronts at the front. The side panels are attached with screws from the inside of the carcass.
If no side panels are used, the gap between the wall and the carcass can be closed with the "Metod vertical cover strip".
Coletrickle_7808
2 May 2015 18:33
Exactly, the kitchen starts on the right with a tall cabinet. This should be flush against the right wall with a filler strip. Ikea doesn’t actually offer this filler strip as standard. I believe people usually take side panels and cut them lengthwise for this purpose, right?
IKEA-Experte
2 May 2015 19:56
With Faktum, it was still possible to use the inexpensive base panels for filler pieces, but with METOD, only end panels can be used.
Coletrickle_7808
5 May 2015 14:54
Yesterday was the day—we went to Ikea and ordered the kitchen. We were very lucky to have a truly knowledgeable consultant who accommodated all our special requests, such as a higher number of legs, etc.! We were also praised for our thorough planning.
The delivery date is June 6, 2015, exactly one day after the move. The price is phenomenal at €2138 (approx. $), and combined with great online deals for the appliances, we’re paying just under €6500 (approx. $) in total. I wouldn’t have even been able to get the carcasses at any kitchen showroom for that price.
Carcasses: Ikea Metod Bodbyn Ivory White €2138 (approx. $)
Oven: Siemens HB75GU550 IQ700 (built-in, pyrolytic, telescopic rails, etc.) €670 (approx. $)
Cooktop: Neff TT5455 Induction FlexZone €615 (approx. $)
Dishwasher: Siemens SX76P030 IQ500 (XXL size, vario hinge) €550 (approx. $)
Extractor hood: Siemens LC68BA572 IQ700 with Clean Air module €650 (approx. $)
Sink: Villeroy & Boch ceramic including mixer tap approx. €450 (approx. $)
Refrigerator: Siemens KG39NXI42 IQ500 / Bosch KGN39XI42 approx. €850 (approx. $)
Worktop: Solid oak, 40mm (1.6 inches) thick, 700mm (28 inches) deep, still needs to be fitted approx. €550 (approx. $)
I’m really impressed. Once the kitchen is finished, I’ll gladly share pictures online.
