ᐅ Which Ikea PAX models are suitable for shared apartments?
Created on: 11 Jan 2020 08:32
Gagaken
I am currently planning to buy new wardrobes for a shared apartment in a larger city and have been looking into the Ikea PAX systems. My question to the community is: which of the many Ikea PAX variants do you think are especially suitable for shared apartments? Important aspects are flexible use, storage space for individual needs, easy assembly, and adaptability to different room sizes.
Are there models that work particularly well for dividing storage space per person, or ones that can be easily modified if the shared apartment changes? I look forward to your experiences and recommendations!
GALENKU
11 Jan 2020 17:50
Gagaken schrieb:
Do you have any recommendations on the best way to divide the interior space for different users? Are there best practices for variable compartments per person in a PAX wardrobe system?
I would reserve a fixed column for each person and separate them visually and functionally with dividers. It also helps to use separate baskets or boxes for smaller items.
sonJohnn49
12 Jan 2020 09:13
Which Ikea Pax variants are suitable for shared apartments?
I recommend the Pax systems with a height of 201 cm (79 inches) and a width of 50 cm (20 inches), equipped with mirrors for each section. This way, every resident gets their own area with a mirror, which helps with daily use and keeps things organized.
ronti
12 Jan 2020 11:47
The advantage of PAX systems for shared apartments is that they are easily modular and adaptable. When space is limited, I often look at narrower units (50cm wide [20 inches]) with swing doors. Sliding doors only make sense if you have little room to open them.
Luke44
13 Jan 2020 08:56
Which Ikea PAX variants are suitable for shared apartments?
I find that especially the combination of a lower height (201 cm, 79 inches) and wider widths (100 cm, 39 inches) in various depths works well, particularly if you plan to use the wardrobe communally.
The option to install individual dividers also makes the wardrobe flexible for shared living situations.
rimole
13 Jan 2020 14:37
Luke44 schrieb:
The option to install individual partitions also makes the closet flexible for shared apartments.
That’s exactly the point! This allows the space to be adapted to different needs, which is very useful in a shared apartment with changing residents.
INGRID34
14 Jan 2020 10:03
Gagaken schrieb:
Are there perhaps models that are especially suitable for separating storage space per person, or ones that can be easily modified if the shared apartment changes?
Yes, the PAX units with corner cabinets and adjustable interiors are very well suited for this. This way, when moving or reassigning the room, you can quickly reorganize or replace individual modules.
