Hello everyone, I recently started planning my kitchen with IKEA Metod cabinets but am facing difficulties due to the limited space in my apartment.
More specifically, my kitchen is narrow and cramped, making it quite challenging to align and correctly install the individual units. Are there any proven techniques or tips for efficiently assembling these Metod cabinets while making the best use of the available space?
I am especially interested in advice regarding tools, handling the individual components—particularly in restricted working areas—and the recommended order of assembly to avoid frustration and mistakes.
Does anyone have experience or tips on how to best install and possibly adapt IKEA Metod cabinets in very tight spaces?
Hello yosefte,
One important aspect that is often underestimated is careful measuring and maintaining the correct installation clearances. Especially in tight spaces, you should work very precisely, as the Metod components are manufactured with tight tolerances.
I recommend thoroughly checking the room before assembly, including verifying wall straightness, for example using a spirit level or laser level. Any unevenness can be compensated with shims or adjustable feet.
You should also definitely consider whether access to the inside of the cabinet will be practical despite the limited space. Sliding doors might be an alternative here, if IKEA offers them for Metod or if you can modify them accordingly.
If you like, I can prepare a checklist for assembling in tight spaces.
yosefte schrieb:
My main concern is advice on tools, handling the individual components—especially when working in tight spaces—and the best assembly sequence to avoid frustration and mistakes.Here are a few final recommendations regarding tools:
- A cordless drill with adjustable torque settings. This helps prevent over-tightened screws or damaged parts.
- A cabinet door puller to make aligning doors easier in narrow spaces.
- Small clamps or brackets for holding parts in place if you’re working alone.
- A broom or a small sliding system to move heavy cabinets smoothly in confined areas without scratching surfaces.
As for the assembly order, I suggest:
1. Install and level the base units
2. Fully assemble and align the lower cabinets
3. Install the upper cabinets
Important: Always check the alignment between each step and adjust multiple times with a spirit level if necessary. I hope this helps!
