Hello everyone, I recently started planning my kitchen with IKEA Metod cabinets but am facing difficulties due to the limited space in my apartment.
More specifically, my kitchen is narrow and cramped, making it quite challenging to align and correctly install the individual units. Are there any proven techniques or tips for efficiently assembling these Metod cabinets while making the best use of the available space?
I am especially interested in advice regarding tools, handling the individual components—particularly in restricted working areas—and the recommended order of assembly to avoid frustration and mistakes.
Does anyone have experience or tips on how to best install and possibly adapt IKEA Metod cabinets in very tight spaces?
Hey yosefte!
You probably know the feeling when you try to assemble a large cabinet in a narrow hallway – it’s almost like being a surgeon in an emergency room, having to get everything done quickly and perfectly in a tight space! 😅
In my “galley” kitchen, I always used small tools, sort of “space helpers”: a small folding stool to temporarily place parts on, and a long spirit level that I attached to the wall to keep both hands free. My tip: Take your time aligning the Metod cabinets and fully screw together all the base units before starting with the wall cabinets. This will save you from constant readjusting.
Also, it helps to unpack and sort all the parts beforehand – being organized is half the battle, even with IKEA! 😉 Good luck and don’t get too stressed out with the screws!
Hello yosefte,
The topic of “tight spaces” when assembling IKEA Metod cabinets is more complex than it might seem at first glance. I will try to explain it from a technical perspective.
- First, it is important to know the exact room dimensions and take them into account when assembling the frame. The Metod system cabinets are modular and adaptable, but most components are fixed in size.
- Second, flexible tools are recommended: a protractor or angle measurer, a cordless drill with torque control, and a small spirit level.
- Third, in compact kitchens it is advisable to assemble the cabinets as close to the wall as possible. It makes sense to pre-fix the base and wall cabinets and only fully tighten the connecting screws once the modules are in their final positions.
One more question for better assessment: How tight is your space exactly? Are there corner solutions (e.g., corner cabinets)? Do you use customizable elements such as Metod plinths and cover panels to hide any gaps?
Please feel free to provide these details—then I can offer you more targeted guidance.
Hello yosefte,
If you are preparing for assembly in tight spaces, I recommend the following structured approach:
- Clear the area as much as possible and ensure good lighting conditions.
- Work with a detailed assembly manual, which you can download online before you start assembling, to familiarize yourself with the steps in detail.
- Avoid unnecessary movements by pre-sorting all parts by function and size.
- For narrow kitchen spaces, it is advisable to assemble the base units and frames first so you can build on them.
- Make sure the cabinets are always securely fixed and properly aligned, as any tilting can cause issues at final assembly points.
If you want to exceed standard dimensions, the Metod components also offer some extension profiles, allowing you to adjust measurements precisely to the millimeter.
Palenar schrieb:
In narrow kitchens, it is advisable to join the cabinets directly at the wall.I completely agree! For me, it was always like a puzzle game: fitting the rectangular components together so that you can hang them with as little leverage and effort as possible, even in tight spaces.
And don’t forget about the fastening systems: there are specially shorter screws and stronger brackets that don’t take up much space.
Don’t get discouraged—sometimes the “tightest spots” end up being the ones that make you happiest in the end 😉
