ᐅ How can a PAX wardrobe system be adapted for use in a hallway?
Created on: 19 Jun 2020 08:37
arvidno
arvidno
19 Jun 2020 08:37
I am currently considering how to redesign the IKEA PAX system to make it ideally suited for use in hallways. The challenge is often that hallways offer limited space, but at the same time require plenty of storage for coats, shoes, hats, and more.
I am not only thinking about pure storage, but also functional and aesthetic adaptations, such as integrated seating for putting on and taking off shoes, coat hooks, or perhaps even hidden features like pull-out shoe drawers.
Does anyone have experience with PAX in hallways? Which modifications or add-ons work well? What would you recommend to make the system not only wall-filling but also practical and cozy?
Thanks in advance!
feklo
19 Jun 2020 09:05
Hello arvidno,
Your idea to customize the PAX system specifically for the hallway is very practical. Here are some tips and considerations that might help you:
- Use narrow units: The 50 cm (20 inches) wide PAX frames work particularly well for narrow hallways.
- Incorporate seating, for example, a sturdy bench with cushioning on top of a deep cabinet, which makes putting on shoes easier.
- Use shelves and pull-out shoe racks to keep things organized and make shoes quickly accessible.
- Hooks can be installed inside or outside the unit, keeping coats and bags within easy reach.
- For added functionality, interior LED lighting can help maintain a clear view inside the storage.
Be careful not to choose cabinets that are too tall if the hallway has low ceilings.
If you have questions about specific modules, just ask!
DULIS
19 Jun 2020 09:57
PAX can be easily customized using a combination of open wall shelves and closed cabinet units. Storage baseboards are great for shoes.
arvidno
19 Jun 2020 10:15
feklo schrieb:
Use narrow units: The 50 cm (20 inch) wide PAX frames are especially suitable for narrow hallways.
That’s a great tip, thanks!
What about the depth? The PAX frames are usually 58 cm (23 inch) deep by standard. Isn’t that too deep for hallways? Are there slimmer options available, or do you have to customize and adjust the depth yourself?
V
vinli
19 Jun 2020 11:03
The standard depth for PAX units is actually 58 cm (23 inches), which takes up a lot of space in many hallways. However, there are narrower versions with a depth of 35 cm (14 inches) that are often used for coat storage or display purposes. These are less flexible for hangers, as garments require significantly more space.
For hallways, it is often recommended to combine the 35 cm (14 inches) deep carcasses for outerwear with smaller side cabinets or open shelves. Those who are handy can also modify the carcasses themselves or use other IKEA products such as METOD carcasses or VARIERA drawers to reduce the depth and create customized solutions.
WARREN
19 Jun 2020 11:19
Making a standard PAX unit simply deeper or shallower is difficult. It is better to cleverly combine the existing modules and create open storage areas on the outside.
