ᐅ How can a PAX wardrobe system be adapted for use in a hallway?
Created on: 19 Jun 2020 08:37
arvidno
I am currently considering how to redesign the IKEA PAX system to make it ideally suited for use in hallways. The challenge is often that hallways offer limited space, but at the same time require plenty of storage for coats, shoes, hats, and more.
I am not only thinking about pure storage, but also functional and aesthetic adaptations, such as integrated seating for putting on and taking off shoes, coat hooks, or perhaps even hidden features like pull-out shoe drawers.
Does anyone have experience with PAX in hallways? Which modifications or add-ons work well? What would you recommend to make the system not only wall-filling but also practical and cozy?
Thanks in advance!
angel
19 Jun 2020 14:22
Regarding practical hallway solutions, from my own experience I can say: it is worth using pull-out trays and drawers for shoes that can be fully extended. This saves a lot of time and helps keep an overview.
Additionally, I recommend planning well-ventilated areas in the lower section, as shoes can otherwise develop a musty smell. Pax is well adaptable here thanks to the wide range of interior fittings.
It is also important to plan the height precisely: around 120 cm (47 inches) is sufficient for coats, while longer coats can be stored in a separate compartment.
If you like, I can gladly explain my planning steps to you.
arvidno
19 Jun 2020 15:48
angel schrieb:
PAX is highly customizable here thanks to the variety of interior fittings.
Thanks for the tip. I’m particularly interested in how to properly integrate a seating bench into the PAX system without it looking too bulky.
Does anyone have ideas on how to best design and implement this both functionally and aesthetically? The seating bench should be sturdy while also providing storage space. Additionally, it would be good if it visually fits well with the PAX system and doesn’t appear out of place.
feklo
19 Jun 2020 16:07
arvidno schrieb:
Does anyone have an idea how to best implement this both aesthetically and functionally?
A very good option is to build a bench based on a lower PAX carcass, about 40 cm high (16 inches). You can then place a sturdy lid made of wood or padded material on top.
For storage, drawers or flap fronts work well, which you can equip with recessed handles or push-to-open mechanisms.
Visually, I recommend matching the fronts to PAX colors (e.g., white or gray) so the bench looks like a cohesive part of the system. Alternatively, you can place a bench as a separate piece of furniture under the PAX system, but this is less space-efficient.
Additionally, it is important that the side panels are reinforced so the seating surface does not sag. There are also special legs or hidden feet designed for such constructions.
DULIS
19 Jun 2020 16:45
A bench on a lower PAX carcass with a top panel. Storage space underneath with drawers or a flap. Simple and effective.
Nauman5
19 Jun 2020 18:21
Just for fun: who really wants a hallway that looks like a furniture store? 😁 For me, a casual coat rack is important too, something that doesn’t feel as rigid as a full closet.
You could really lighten up the PAX wardrobes by adding a few open compartments or baskets – it looks more homely and makes the whole space feel cozier than just rows of “PAX, PAX, PAX.”
A bench with colorful cushions can also make the hallway feel really welcoming.
V
vinli
20 Jun 2020 09:11
One point not mentioned yet: ventilation and moisture management in the hallway are crucial.
If you want to use PAX closets in the hallway, make sure that especially closed cabinets have regular ventilation or use open elements to prevent mold or odor buildup.
Also, plan for protection against scratches on the fronts caused by bags or keys early on, using special coatings or films.
