ᐅ How can IKEA Hemnes be used sustainably in a DIY project?
Created on: 28 May 2016 14:07
kirstenk61K
kirstenk6128 May 2016 14:07I plan to repurpose the IKEA Hemnes furniture in a DIY project with a focus on sustainability, and I would like to start a discussion here to gather and share different approaches.
Specifically, I am interested in how to best utilize the material and construction of the Hemnes without completely dismantling or discarding it, through upcycling or meaningful redesign. What methods and techniques are suitable for preserving the natural wood grain while achieving a durable, sustainable result?
I am thinking not only about furniture conversions but also smaller projects such as decorative elements or multifunctional furniture pieces. Are there any experiences with eco-friendly wood treatments or special tools that make working with the material easier without increasing the environmental footprint?
I would appreciate well-informed answers that also address potential challenges or common mistakes when reusing the Hemnes.
The Hemnes is made of solid pine wood panels, which can be easily sanded and refinished.
For sustainable DIY, treatment with oils such as linseed oil or wood wax is recommended. These are environmentally friendly and preserve the natural appearance.
For the conversion: Make sure not to damage any screws so that everything can be reassembled.
Your question touches on many important points, especially preserving the wood structure while ensuring sustainable use. I often use the Hemnes series myself because although the pine wood is soft, it is relatively durable and recyclable.
I recommend the following detailed steps for processing:
- First, completely disassemble the piece of furniture and inspect all connection points.
- Sanding: Start with a grit of about 120 to remove old coatings. Then move to finer grits like 180 or 220.
- Ecological finishing: Use untreated natural oils or wax (hard wax or beeswax). These finishes are not only sustainable but also allow the wood to breathe.
- Make sure not to use lacquer or chemical products that seal the wood and thus compromise sustainability.
What function is your new project supposed to serve? For example, a shelf, a bench, or something else?
Also important: Do not damage screws and dowels during disassembly to ensure reusability.
Do you already have an idea of how much craftsmanship experience you have?
I find it interesting how often sustainability in upcycling is only considered on a superficial level. Just because a piece of furniture is repurposed doesn’t automatically mean the final product is truly more sustainable.
This is exactly where I see the crucial point. DIY projects using Hemnes furniture often result in less durable solutions because the original construction isn’t designed for different types of loads.
Therefore, before starting any modifications, I would first check whether the Hemnes wood and its joinery methods are really suitable for the new intended use.
Also: Which ecological oils or varnishes are actually more sustainable than traditional ones? This should be verifiable rather than relying solely on certifications or promises.
difepeo schrieb:
Therefore, before processing, I would first verify whether the Hemnes wood and its connection methods are truly suitable for the new usage profile.I agree completely; especially in terms of stability, custom-built constructions are often weaker.
Regarding sustainable oils: untreated linseed oil is a classic example—it is biodegradable and naturally non-toxic. For those who want to be absolutely sure, they can review the relevant technical data sheets or opt for products certified as organic.
For Hemnes, which is pine wood, I also recommend applying a UV blocker if it is used outdoors. This prevents premature aging and offers protection through natural chemical means.
One more important point: when doing maintenance, it is essential to consider environmental factors—so avoid using solvents or materials that release formaldehyde.
kirstenk6130 May 2016 08:22fidasI schrieb:
What function is your new project supposed to serve? For example, a shelf, a bench, or something else?Thank you for the detailed answer! I am currently planning to build a kind of multifunctional stool with storage using Hemnes components. It should be sturdy enough to be used as a seat but also remain versatile and visually appealing. The idea is to make the piece as modular and possibly extendable as possible – I might want to add elements later on, so the connections are very important.
I have advanced skills in craftsmanship. I have already modified and painted smaller furniture pieces, am familiar with sanding techniques and wood treatments, but I want to improve sustainability at every step, especially regarding the choice of tools and consumables.
Are there any specific tips for modular construction with Hemnes parts or for reusing screws and dowels that I should definitely keep in mind?
