ᐅ Which DIY projects using Ikea Hemnes furniture are suitable for beginners?
Created on: 22 Oct 2023 08:27
likeo54
likeo54
22 Oct 2023 08:27
Hello everyone, I am considering trying out DIY projects with Ikea Hemnes furniture, especially as a beginner like myself. From your experience, which projects are suitable for beginners? I have a general idea of the products but would like to know which modifications or alterations can be done without extensive DIY skills. Detailed advice on tools, materials, and possible pitfalls would be appreciated. What would you recommend for someone looking to start safely and with a manageable amount of effort?
sanjon
22 Oct 2023 09:03
My recommendation for beginners is simple color changes: sanding furniture, priming, and repainting. Hemnes works well for this. Tools: sandpaper, brushes, paint. No major structural changes to keep mistakes minimal.
Deandre
22 Oct 2023 11:17
That’s a great question! I would also suggest starting with simple projects, such as updating a dresser top using adhesive film or wallpaper. This requires little to no craftsmanship experience and can be done without extensive tools. It is important to prepare the surface well, possibly by lightly sanding it with fine sandpaper. This helps the film adhere better. For beginners, experimenting with small modifications is a good way to start and gradually take on more complex projects.
Nathanaelk
22 Oct 2023 13:42
To expand the discussion about DIY projects with Hemnes for beginners: I would first recommend thoroughly understanding the construction of Hemnes furniture. The design inspired by late 19th-century styles is relatively sturdy, mostly made from solid wood components, and can be modified in various ways.
Beginners can, for example, modify the legs by unscrewing them and replacing them with custom-designed legs—ideal for changing the height or the overall look and feel. Tools needed: cordless screwdriver, drill, screwdriver. It is important to pay close attention to the attachment points to maintain stability.
Alternatively, doors or drawer fronts can be enhanced by cutting patterns or adding decorative molding. Careful measuring and possibly a fine saw will be helpful for this.
A small warning: When removing drawer fronts, be cautious because fittings are often hidden. Check videos or instructions beforehand to avoid damaging the furniture.
sanjon
22 Oct 2023 14:06
That’s a good tip; swapping legs usually goes quickly and is relatively simple.
likeo54
23 Oct 2023 07:51
Thanks for the information so far! To narrow it down: Would you say that projects involving color changes plus minor structural modifications (such as replacing legs) are doable without prior experience? I own a cordless drill but I'm unsure about surface preparation and, in general, the exact steps to follow to avoid a sloppy finish. Is there a standard procedure or step-by-step guide that beginners can easily understand?
