ᐅ Which DIY projects using Ikea Hemnes furniture are suitable for beginners?
Created on: 22 Oct 2023 08:27
likeo54
Hello everyone, I am considering trying out DIY projects with Ikea Hemnes furniture, especially as a beginner like myself. From your experience, which projects are suitable for beginners? I have a general idea of the products but would like to know which modifications or alterations can be done without extensive DIY skills. Detailed advice on tools, materials, and possible pitfalls would be appreciated. What would you recommend for someone looking to start safely and with a manageable amount of effort?
Deandre
23 Oct 2023 10:04
From my experience, combining a color change with replacing the legs is really suitable for beginners. The most important step is surface preparation:
- Thoroughly clean and degrease the furniture
- Lightly sand to roughen the old surface
- Remove dust thoroughly
- Use a primer if you are switching from lacquer to paint
When replacing the legs, make sure the new ones use compatible screw holes or adjust the fastenings accordingly. A good cordless drill makes screwing easier, but it is important not to tighten too much to avoid damaging the wood.
Anyone who follows a step-by-step guide can hardly go wrong. Patience is key!
mauka
23 Oct 2023 12:57
I think that already sounds quite achievable! You shouldn’t make it too complicated at the beginning – a project like “swapping Hemnes legs and painting them” is a great combination that feels like a small success. A bit of sandpaper and a good mood, and you’re good to go. And if the paint isn’t perfect, it’s easy to start over with a piece of furniture like that. Making mistakes is part of the process 🙂
And hey, the main thing is that in the end, you have something you like, right?
Lukesan
23 Oct 2023 13:46
likeo54 schrieb:
Standard procedure or step-by-step guide, especially easy for beginners to understand?
Yes, for surfaces:
- Clean
- Sand
- Prime
- Paint
Replacing legs: screw on, adjust holes if necessary. Done.
Goixkin
24 Oct 2023 08:22
Beginners can also refresh Hemnes dressers with new handles. It requires little effort but makes a noticeable difference. You only need a screwdriver and possibly new matching screws. A simple modification that takes little time and does not require large tools or advanced skills.
likeo54
24 Oct 2023 09:11
The idea with the handles sounds good too – I almost forgot about that. Thanks for the reminder! From your experience, is there anything to consider when replacing the handles, especially for the Hemnes? Anything regarding the screws, the drilling, or similar? That would be a really simple starting point alongside paint and legs.
