ᐅ How can IKEA BRIMNES doors be adjusted for smooth operation?
Created on: 22 May 2023 10:32
jusufpiI noticed that the doors of my IKEA Brimnes wardrobe do not operate very smoothly and feel somewhat stiff in certain areas. My question to the community is: How can the doors of the IKEA BRIMNES wardrobe be easily and quickly adjusted so that they open and close much more smoothly and cleanly? I would appreciate precise tips on adjusting the door hinges or advice on which adjustment screws or mechanisms are relevant for this model. Thank you in advance!
With BRIMNES, you can adjust the doors using the adjustable hinges.
- Turn the screw at the top of the hinge to adjust the height
- Turn the screw on the side to adjust the depth
- Turn the screw at the front/regular position to adjust the lateral position
Usually, it helps to hang the doors slightly higher and optimize the side alignment. Cleaning the hinges from dust or stuck grease can also be beneficial.
Basically, the BRIMNES doors have simple metal hinges that can be easily adjusted. I recommend the following approach:
- First, carefully loosen all screws and then readjust them to ensure the doors fit precisely within the frame.
- Use a screwdriver with a good grip to avoid damaging the small adjustment screws.
- Sometimes lightly lubricating the moving parts with a dry silicone spray improves smoothness without applying grease that attracts dust.
- If the doors still feel stiff after adjustment, check the hinges for slight bending or if the top screws are not tightened enough.
- For perfectly even alignment, it helps to gently move the door from the outside while adjusting to find the ideal fit.
These tips are based on my experience with similar models – hope this helps!
As an addition, I would like to point out that IKEA uses two main types of hinges for BRIMNES doors: standard cup hinges and, in some cases, clamp hinges. It is important before adjusting to:
- Clean the hinges thoroughly to prevent dirt from accumulating between the moving parts.
- Make adjustments gradually by turning the adjustment screws step by step to observe how the door changes.
- The three adjustment options control height, side, and depth respectively.
- If the doors are too difficult to open, checking the fitting position within the cabinet body can help, as incorrect installation of the furniture can hinder door operation.
If you have any further specific questions about adjustment, feel free to ask!
Deandre schrieb:
The adjustment is best done by gradually turning the adjustment screws to get feedback on how the door changes.I think this sums it up well. I once had a BRIMNES model with sticky doors, which was really frustrating. What helped me was making very gentle adjustments in small steps – that way you can clearly see how each turn of the screw affects the door.
I would also recommend taking your time and not rushing, especially if you’re new to this kind of adjustment. It can feel overwhelming at first, but if you carefully observe the door’s movement, you’ll quickly find the perfect setting.
A little encouragement to everyone working on their furniture right now: it’s worth it! A properly adjusted door hinge makes using the furniture much more enjoyable and is a real comfort upgrade.
