ᐅ How can I protect IKEA Metod cabinet fronts from fading due to paint?
Created on: 7 Sep 2015 10:23
lizachar35
I have a question that’s been on my mind lately: How can I protect IKEA Metod cabinet fronts from premature color fading?
Some time ago, I installed a kitchen with Metod fronts and noticed that the color noticeably fades in areas exposed to strong sunlight. Unfortunately, IKEA does not provide specific recommendations for additional surface protection.
I am particularly interested in which products or methods can improve the durability of the painted surface without affecting the appearance or feel of the fronts. Are there special coatings, sealants, or care products that are practical for this purpose?
Additionally, any tips on substances to avoid during cleaning or maintenance would be helpful, especially those that might damage the fronts or contribute to further fading.
I look forward to your experiences and recommendations, as I want to avoid experimenting with just any product and ensure the fronts stay looking good over time.
Thanks in advance for your support!
leebi7
9 Sep 2015 08:26
Hello lizachar35,
to address your original question in detail: If you have Metod fronts from IKEA, the surface is usually melamine-coated or painted. Neither option is specifically designed for high UV resistance, as they are primarily focused on offering good value for money. This means that some fading is inevitable with intense sunlight exposure.
- If you still want to take preventive measures, I recommend a multi-step approach:
- 1. Window replacement or application of UV protection films: There are methacrylate-based films available that block over 90% of UV radiation and can significantly reduce the stress on the fronts.
- 2. Surface sealing: A thin, breathable clear coat with UV protection based on polyurethane can be applied. It is important that the surface is well prepared: clean with an alkaline-free cleaner, lightly sand with 240-320 grit, and thoroughly remove dust.
- 3. Maintenance: Regular use of furniture wax (without silicone additives) helps protect the surface and maintains gloss and color depth.
Always test on an inconspicuous area before painting to check for any surface changes or dissolving. Make sure to apply the new protective layer thinly and evenly to avoid visible differences.
One last important note: On glossy surfaces, the clear coat can slightly alter the gloss level, usually shifting it towards a matte finish, depending on the varnish type.
I hope this clarifies things.
One more important question: How exactly is your kitchen exposed to sunlight? I ask because there is a difference between direct sunlight hitting the fronts and just ambient light exposure.
