ᐅ How can I clean matte IKEA Metod cabinet fronts without leaving streaks?
Created on: 9 Mar 2023 08:12
keopi
Hello everyone, I have matte painted IKEA Metod kitchen cabinet fronts and I’m facing the problem of cleaning them without streaks or smudges. I have already tried regular all-purpose cloths and mild cleaners, but often an unpleasant haze remains that spoils the appearance. I’m especially interested in tips on which products to use and in what order to proceed to thoroughly and streak-free clean matte finished fronts, without damaging or harming the surface. Has anyone had similar experiences? What are your tried and tested methods or products?
theo63
9 Mar 2023 14:32
Bagupo schrieb:
Use a soft microfiber cloth, slightly dampened with clean water. No cleaner! Then polish with a dry, clean cloth.
That sounds reasonable, but this method does not work for stubborn grease or fingerprints.
Has anyone had experience with the effects of diluted dish soap or vinegar-water mixtures on matte IKEA fronts? I am also wondering whether the matte finish could be damaged by this.
Lotizar
10 Mar 2023 08:01
Matte finishes are particularly sensitive to acidic cleaners – I would therefore avoid vinegar or citric acid.
Dish soap in a diluted concentration and with a neutral pH is usually safe because it dissolves grease and is not aggressive. The key is using the correct dosage and immediately wiping thoroughly with clean water.
Another tip: pay attention to the quality of microfiber cloths, as some cheap fibers can leave residues themselves.
A cleaning method recommended for IKEA Metod fronts is based precisely on gentle removal using a slightly damp cloth, a mild cleaner, and a dry polishing cloth.
brianna
10 Mar 2023 09:48
I completely understand the frustration of cleaning without achieving a spotless result—especially with matte fronts, where every stain and streak is much more visible.
If anyone has had similar experiences: Sometimes it helps to think of the cloth used as something to be replaced during the cleaning process. I have found that it’s best to have several clean cloths on hand, so the second or third cloth can still pick up residues and moisture effectively.
This can be tiring but significantly reduces streaks in the long run.
Trate47
10 Mar 2023 12:37
brianna schrieb:
If anyone has had similar experiences: Sometimes it helps to think of the cloth used as just a change during cleaning.
Exactly! And if it doesn’t work out again, maybe the kitchen is just jealous and wants an extra shine day to relax 😉 But seriously, using fresh cloths more often means fewer streaks!
andre3
11 Mar 2023 07:24
theo63 schrieb:
Has anyone had experience with the effects of diluted dish soap or vinegar-water mixtures on matte IKEA cabinet fronts?
From a technical perspective, overly aggressive cleaners can damage the surface or cause it to appear dull over time. Vinegar is not suitable due to its acidity.
Dish soap with a neutral pH and used in very small amounts is the best option, followed by thorough wiping with clean water and drying by polishing. This protects the surface and prevents streaks.
