ᐅ How can I prevent the BILLY shelf unit from wobbling when opening the doors?
Created on: 16 Oct 2021 09:17
Maksim52
Hello everyone, I have an issue with my IKEA Billy bookshelf, specifically with the doors. Whenever I open them, the entire unit starts to wobble slightly, which is quite annoying, especially with a fully loaded version, and also poses a safety risk. The bookshelf is standing on a standard laminate floor without any unevenness. I have already made minor adjustments to the doors, but the problem persists. Does anyone have tips or experience on how to prevent the wobbling when opening the doors? What additional measures, such as proper wall mounting, extra stabilization, or adjustments, could help? I appreciate all suggestions, including technical details or proven solutions.
SAWYERR
16 Oct 2021 12:37
Additionally: Test the doors regularly while adjusting. Open and close them—pay attention to their stability. This way, you can immediately see if the adjustment is effective.
Maksim52
16 Oct 2021 19:46
Update from this evening: I also installed a central wall bracket and adjusted the doors according to FEKAU’s sequence (height, sideways, depth). Additionally, I placed small felt pads on the baseboard to compensate for any slight unevenness. Result: The shelf now hardly wobbles when opening the doors. Adjusting the hinges really made a big difference, as I initially didn’t know that the doors could pull. Thanks to everyone for the valuable tips! If anyone has any other ideas on how to further stabilize the shelf, please share.
bupar
17 Oct 2021 08:04
Glad to hear that the measures are helping. If desired, elongated holes can be drilled in the shelf, allowing the mounting screws to be adjusted so the shelf is securely fixed against wall movement. For very bulky or heavily loaded shelves, reinforcement with metal brackets inside the cabinet, which are screwed to the wall, is also possible. These prevent long-term wobbling or tipping, even as the structure ages. It is also important to regularly check that the screws remain tightly fastened.
LENNAU
17 Oct 2021 08:18
It's great that your shelf is now stable! One last tip: distribute the load evenly and store heavy books at the bottom rather than on top. This lowers the center of gravity and noticeably reduces tipping movements. If you add doors or extensions in the future, always consider the additional loads.
