ᐅ How can I improve the stability of a tall wardrobe?
Created on: 27 Mar 2022 18:43
Ploru
Ploru
27 Mar 2022 18:43
Hello everyone, I recently purchased a very tall Pax wardrobe from IKEA and am now facing the issue of how to increase its stability. Specifically, the height and depth of the wardrobe make it seem particularly prone to tipping—especially when fully loaded. I have already considered using additional wall fastenings, but I am unsure if that is sufficient or if there are better methods to reduce the risk of tipping and minimize vibrations. I am also interested in whether there are recommended reinforcement materials or alternative mounting systems that can be used without significantly changing the wardrobe’s appearance. Does anyone have experience with tall Pax wardrobes and advice on improving their stability? I would appreciate any suggestions!
lorena
27 Mar 2022 19:16
Hello Ploru, first of all, you raise a very good point. Stability with tall Pax wardrobes can quickly become an issue, especially when they are fully loaded with clothing or even heavy items.
The first thing to always do is use the supplied wall fasteners – these are specifically designed to prevent tipping. It is important that the fixing points are anchored into load-bearing walls such as concrete or structural masonry. Unfortunately, simply attaching to drywall alone is often not sufficient unless special drywall anchors are used.
Additionally, I recommend stabilizing the wardrobe at the base with a combination of skirting boards or plinth extensions. This provides a larger support area. Reinforcing cross braces inside can also be installed to protect the side panels from bowing.
Have you checked whether your floor is completely level? Unevenness can increase the risk of tipping. Using shims or wooden blocks to compensate might be helpful.
What is the exact height of your Pax wardrobe, and approximately how heavily is it loaded? The type of doors (sliding doors vs. hinged doors) can also have an impact, as sliding doors, for example, require different stabilization methods.
bensau
27 Mar 2022 19:37
lorena schrieb:
First of all, you should definitely use the supplied wall fasteners – these are specifically designed to prevent tipping over.
I can only agree! Especially with tall cabinets, screwing them into the wall is your best friend.
I would add this: If you want it really stable, build a small baseboard or basically put "feet" under the cabinet. This slightly raises the cabinet and provides better stability because it increases the contact area with the floor.
And hey, a bit of wood glue or screws here and there never hurts, as long as you don’t completely ignore the IKEA logic 😉.
In short: wall fastening + definitely check the floor + if necessary, reinforce the interior – then the Pax will be unbeatable in stability!
JAMESONB41
27 Mar 2022 20:02
Important: Use wall anchors; otherwise, the cabinet may tip over under load. If the floor is uneven, use leveling wedges. Internal cross braces increase stability.
PRA64
28 Mar 2022 08:15
To sustainably increase the stability of a tall Pax wardrobe, I recommend the following approach:
- Check the wall structure to select appropriate anchors and screws for mounting.
- Install the supplied or optionally reinforced wall brackets at least on two levels (above and below the wardrobe’s center).
- Add one or more cross braces inside to connect the side panels and prevent twisting.
- Inspect and, if necessary, level the floor beneath the wardrobe; use shims to compensate for unevenness.
- For very tall wardrobes, a combination of wall mounting and a baseboard can be beneficial.
It is important to follow the assembly instructions precisely to avoid stresses outside the specified load areas. When using additional materials, consider the appearance, as some reinforcements might be visible.
Lotizar
28 Mar 2022 10:24
PRA64 schrieb:
Attach the supplied or optionally reinforced wall anchors in at least two levels (above and below the center of the cabinet).
This recommendation is exactly what I also suggest. The important factor is the distribution of the mounting points. Securing it at only one spot increases the risk of tipping and can even put stress on the material.
Furthermore, it is essential that the screws penetrate at least 6 cm (2.4 inches) deep into a solid substrate such as masonry or solid wood. Drywall is always critical; special metal or spring anchors are required in these cases.
I would also like to point out the internal cross braces, which reduce lateral bending and significantly increase the overall rigidity. This is an especially important factor in tight spaces.
Additionally, regularly checking for loose screws is advisable, as cabinets are prone to vibrations during everyday use.
