ᐅ How can I equip Ikea Metod drawers with soft-close mechanisms?
Created on: 9 Feb 2023 08:17
naupe
I recently purchased an Ikea Metod kitchen system and now want to retrofit the drawers with a soft-close feature. I am particularly interested in which soft-close mechanisms are compatible with the standard Metod drawers and how exactly to convert or replace the existing drawer slides. Specifically, I would like to know whether it is necessary to replace the entire drawer slides with soft-close models or if there are adapters or retrofit kits that can be integrated.
Also, it would be great if someone could explain if there are any special considerations during installation, such as calibration or adjustment steps, to ensure the soft-close function operates smoothly and lasts a long time.
Thanks in advance for your advice!
Surela
9 Feb 2023 15:39
[quote=naupe, post: y7c0q3, member: XXX]
"Do you have any experience with third-party slides that are compatible?"
Yes, I have fitted several Metod cabinets with affordable slides from brands like Blum or Hettich, which fit well into the Ikea frame. Here are some points to consider:
- Compare measurements: Often they are identical or slightly different, but the most important factor is the distance between the mounting holes.
- Quality: Established furniture hardware brands usually offer more durable products than cheap no-name solutions at Ikea prices.
- Function: The soft-close mechanism works similarly, and with full-extension slides it is often even smoother.
What can be a bit more challenging are the slightly different screw positions. Sometimes you need to drill new holes, but this is relatively easy to do with the Metod carcass.
Regarding the type of slide: Full-extension slides with soft-close generally perform better because they move out smoothly and run steadily throughout. Partial-extension slides are a bit simpler, but the difference is not significant.
In general: It’s better to invest in good slides as it pays off in the long run. If you’re unsure, I can help you choose suitable models.
ju_ren
10 Feb 2023 09:06
One more tip for installation: If the drawer is stiff after being fitted, first check whether the runners are completely straight and all screws are tightened. Sometimes the runners are slightly misaligned, which increases friction. Also, make sure the soft-close spring is not obstructed. After installation, open and close the drawer slowly several times to allow the mechanism to "bed in."
SETHBLA
11 Feb 2023 07:48
I simply bought replacement soft-close rails from Ikea and swapped them for the old ones. It was straightforward and required no major effort; you just need the right screwdriver. I didn’t have to adjust anything, everything worked smoothly on the first try.
