ᐅ How can I customize IKEA Metod cabinets with paint or adhesive film?
Created on: 5 May 2021 09:12
Ilir1
Hello everyone, I am planning to customize my IKEA Metod kitchen and pantry cabinets and am especially interested in ways to enhance their appearance using paint or adhesive films. I would like to know which types of paint (e.g., lacquer, chalk, or acrylic paints) are suitable, how they can be applied to the surfaces, and which kinds of films provide a durable and attractive finish. Tips on surface preparation, protection after painting or applying films, and potential challenges during the process would also be very helpful. Perhaps someone has experience with specific brands or techniques that work particularly well or not so well. Thank you in advance for your detailed feedback!
Ilir1
5 May 2021 12:10
Thank you for the valuable advice so far! I am leaning towards a combination of paint and foil, for example, painting some fronts and contrasting others with foil. In this regard, I would like to know how well foils can be applied to edge cabinets. I imagine the edges are particularly challenging since they are often not completely smooth and are frequently rounded. Should the foil be cut at these points or overlapped? How resistant is the foil to abrasion in these areas? For the paint layer, I am definitely planning a matte finish—do you have any recommendations for suitable types of paint?
Timmyse36
5 May 2021 12:44
Ilir1 schrieb:
I am leaning towards a combination of paint and film, like painting some fronts and contrasting others with film.
That sounds great. I have applied film on edges myself, and you really need a sharp blade and a lot of patience. I usually wrapped the film around the edges in small sections and carefully fixed it with a heat gun. Overlapping is also possible, but it can quickly look thick. Abrasion on edges may occur if the adhesion is insufficient – so it’s essential to use high-quality films specifically designed for furniture.
bupar
5 May 2021 13:16
For working with films on edges: Professional furniture trainers recommend using only films with high elasticity and a self-adhesive backing on edges. After application, the surface should be heated with a hot air gun to about 50-60°C (122-140°F) and firmly pressed down with a squeegee to ensure maximum adhesion. Overlaps should be avoided if possible, as they can create defects. For matte finishes, acrylic paints specifically designed for wood and plastic surfaces are suitable, as they are abrasion-resistant and UV-stable.
theota
5 May 2021 13:48
Interesting that everyone focuses so much on membranes and paints, considering surface preparation as the most important factor. To be honest, I find membranes to be quite a drastic downgrade of the original appearance – these adhesive films often feel cheap and age poorly. Painting makes more sense in that regard, but then perhaps you should reconsider whether to buy a new Metod unit altogether? For individuality, there are much more creative options today, such as real wood veneers or even 3D films! Why not try something truly unusual?
Ilir1
6 May 2021 08:05
theota schrieb:
Painting makes more sense in this case, but then maybe it’s worth reconsidering whether to buy a new Metod unit altogether?
That’s an interesting point, and I do see the limitations of standard Metod fronts. However, I don’t want to replace everything completely; rather, I have spaces where I want to achieve a visual change with a limited budget and less effort, without replacing the entire kitchen. My intention is more to give the existing setup more character – which is why the combination of paint and films seems like a good compromise to me. Real wood veneers or more elaborate solutions are definitely nice but often come with different cost and craftsmanship considerations.
JONKO
6 May 2021 08:55
I can understand the concerns raised by theota, but for me, sustainability is also important: instead of buying everything new, I think using paint or films is a great way to conserve resources. I have experimented a lot with applying films in particular. My tip: for curved or rounded edges, so-called stretch cuts in the film help. These are carefully scored to allow the film to form smoothly without wrinkling. And yes, high-quality adhesive is crucial for durability.
