ᐅ How can I clean IKEA Besta furniture more effectively without causing damage?
Created on: 25 Dec 2023 14:17
MentorHello everyone,
I have had several IKEA Besta furniture pieces in my living room for some time now, and I would like to clean them more thoroughly while being gentle. My goal is to clean the surfaces and edges without damaging the coating or the material. So far, I mostly use a damp microfiber cloth and occasionally a neutral household cleaner, but I wonder if there are more effective methods that also preserve the furniture’s durability. Perhaps you have experience with special care products, cleaning techniques, or home remedies? Which cleaning agents should definitely be avoided to prevent scratches, discoloration, or peeling? Tips on handling hinges, handle areas, or glass tops of the Besta system are also welcome.
Thank you in advance for your suggestions!
Hello! 😄
I know this very well, especially with Besta cabinets and their smooth surfaces, which you definitely don’t want to treat with harsh methods. My tip: Gentle cleaning is key. I always use a soft microfiber cloth, slightly dampened with lukewarm water, and for tougher spots, I use a mild dish soap solution.
Very important: No abrasive cleaners or strong chemicals, as these can cause the decorative foil surface to peel off quickly. For the glass inserts, I also use a regular glass cleaner spray, which works great without scratching or leaving streaks.
And, for that extra touch, I lightly buff everything afterwards with a dry cloth – it then looks as if the furniture was just assembled. 😉
What I never do, however, is use overly wet cloths; the furniture doesn’t like that at all.
Wesley schrieb:
Very important: Avoid abrasive cleaners or harsh chemicals, as they can quickly cause the protective film coating to peel off.I completely agree, but I also see this issue critically: IKEA often gives only vague care instructions, and many people then resort to completely generic cleaners, which can be effective but also harmful to the furniture.
I wonder: Why doesn’t IKEA switch to more sustainable or durable materials that can handle stronger cleaning? But as long as the furniture remains so sensitive, you just have to be careful. Personally, I avoid cleaners containing alcohol or any solvents.
By the way, are you sure that “mild dish soap” won’t damage the surface over time? I prefer to use only distilled water or an extremely mild soap solution – everything else seems too risky to me.
Here are some practical tips based on my experience cleaning IKEA Besta furniture:
- Preferably use a soft, lint-free microfiber cloth, slightly dampened with lukewarm water if needed.
- For tougher dirt, a few drops of mild, pH-neutral dish soap mixed in water can be effective; avoid aggressive cleaners.
- Damage to coatings and laminates mainly occurs through mechanical stress or solvents in cleaning products, so do not use cleaners containing alcohol or ammonia.
- Cleaning handles and hinges works well with a small brush or cotton swab to reach difficult spots.
- Standard glass cleaners are suitable for glass elements but should be used sparingly to avoid streaks on the surface.
Another recommendation is to avoid standing water on the furniture surfaces—wiping them dry immediately prevents water marks and swelling of edges.
warrenka5726 Dec 2023 19:08I would like to join the discussion from a slightly more emotional perspective. I used to have Besta furniture, and one day I accidentally used a too harsh cleaner. The result was a slightly roughened surface – really frustrating because the furniture was supposed to look modern and smooth.
That’s why I can really understand when others here are cautious and looking for gentle cleaning tips. It’s worth finding the best balance between clean and undamaged.
That is important! I also found that mechanical impact can be just as harmful: it’s better to use a soft cloth, not abrasive sponges or brushes.
Finally, a tip: take your time cleaning, focus on small areas, and allow the furniture to dry undisturbed after wiping.
Vinlen schrieb:
Damage risks to coatings and films mainly come from mechanical impact or solvents in cleaning products, so please avoid cleaners containing alcohol or ammonia.
