ᐅ Has anyone placed their KALLAX unit outdoors? If so, how did you protect it?
Created on: 29 Mar 2022 08:13
christatau
I would like to know if anyone here has permanently placed their IKEA KALLAX shelving unit outdoors? I am especially interested in how you protect the furniture from weather conditions like rain, snow, or UV exposure.
The shelf is planned to be placed in my garden under a partially covered area that does not fully protect it from moisture. Considering the materials (particleboard, lacquered surface), I’m wondering if it makes sense to seal it additionally, treat it with varnish or a special film, or if it even needs to be fully impregnated.
Does anyone have experience with using KALLAX outdoors? Are there any tips to increase its durability without compromising the design?
I’m looking forward to your advice and feedback!
minan
29 Mar 2022 14:50
Josefane schrieb:
Are there any studies or long-term tests that truly recommend a protective measure?
This is an important point. From my experience—now over 12 months of regular observation—the following weaknesses have become particularly clear:
The original melamine coating can resist splashes for a while, but with direct or prolonged exposure to moisture, the edge quickly swells.
However, targeted sealing can significantly extend protection—up to one year of good protection with careful application, and longer if the environment is fully protected.
In my opinion, multiple layers of sealing are necessary to ensure long-term protection. I can provide details on the application of each protective layer if there is interest.
Parbo
30 Mar 2022 07:12
To add technical details to the discussion, here is my contribution:
KALLAX is made of medium-density fiberboard (MDF) or particleboard with a melamine coating. These materials are naturally hygroscopic, meaning they absorb moisture and consequently change their structure.
For outdoor use, I recommend a multilayer sealing process:
1. Pre-treatment: Sand all surfaces and edges with fine sandpaper (grit 180-220) to improve the adhesion of the sealants.
2. Edge sealing: Since the material is often exposed at the edges, epoxy resin or special edge varnishes that close the pores tightly are suitable.
3. Priming: Apply a water-resistant primer that impregnates the wood and enhances the adhesion of the topcoat.
4. Surface coating: Apply at least two layers of polyurethane varnish or resin-based exterior paint. Each layer must dry completely.
5. Installation: Use spacers to prevent moisture buildup at the base.
This treatment requires time and care but significantly protects the furniture from moisture and UV exposure.
jotisi
30 Mar 2022 09:18
Josefane schrieb:
Why would someone try to modify a piece of furniture originally designed for indoor use?
That’s a point I find interesting as well.
A KALLAX shelf unit is simply stylish, affordable, and versatile – which makes it tempting to use outdoors too.
However, instead of spending hours sealing it, it might be worth considering whether to recreate the design or concept using outdoor-grade materials.
Ultimately, it comes down to a question of effort versus benefit: How long will a KALLAX unit actually last outside? And is it worth going against its original intended use?
I think it’s fine as a temporary solution, but in the long run, it’s too much effort and carries too much risk.
praWarre69
30 Mar 2022 11:44
Tips like these are really valuable! I used to just use clear spray paint and thought that was enough – unfortunately, it isn’t.
But with your approach, it will be a more durable solution. Maybe you could also use a weatherproof furniture cover after painting; that way the KALLAX even looks stylish and stays in good condition longer 😉
Thanks for the detailed instructions!
klo40
30 Mar 2022 15:57
jotisi schrieb:
But instead of spending hours sealing, one could also consider whether to realize the design or idea in outdoor materials.
Absolutely right. Those who love the classic KALLAX design should probably look for outdoor shelving made of aluminum or weather-resistant plastic, which offer the same modular look.
The effort to protect a KALLAX shelf outdoors from the elements rarely justifies the benefit.
However, for DIY enthusiasts with time, your idea is certainly intriguing – in this case, precise sealing is essential.
minan
31 Mar 2022 08:01
One final note from me:
In addition to moisture, sunlight exposure also plays a significant role in the aging of the material. UV light can cause the melamine surface to fade and become brittle over time.
Therefore, I strongly recommend using a UV-resistant coating for outdoor installations – there are special paints with UV protection that are very effective in this regard.
And as mentioned before: make sure the area is well ventilated to prevent trapped moisture.
I hope this provides an even more comprehensive overview!
