ᐅ Experiences with cover panels for Kallax units in outdoor areas?
Created on: 25 Jul 2015 08:37
Jandra
Jandra
25 Jul 2015 08:37
I am planning to use a Kallax shelf from Ikea outdoors to store plants and some gardening tools. Since the shelf is obviously not weatherproof, I am considering using cover panels as protection against the weather. My question to you is:
What experiences have you had with cover panels for Kallax shelves used outdoors?
In particular, I am interested in:
- Which materials have proven to be especially durable against rain, sun, and temperature fluctuations?
- How do you attach the panels to the shelf so that they are secure but can still be replaced if needed?
- Are there any tips for maintaining or protecting the panels against mold or warping?
- And perhaps, whether using these panels has affected the usability of the shelf (e.g., limitations on ventilation or accessibility).
I would appreciate detailed feedback, as I do not intend to leave the shelf outside only temporarily. Thanks in advance!
Genuan
25 Jul 2015 09:22
I used MDF boards that were painted with waterproof paint. They hold up well, but the edges should be sealed additionally. I fastened them with small metal brackets, which I screwed in at the bottom.
HORST41
25 Jul 2015 10:11
I find this topic really challenging. I had my Kallax shelf standing in the garden and placed a plexiglass sheet on top to protect it from rain. At first, everything went well, but after about six months, the edges of the Kallax had swollen. I was quite disappointed because I had hoped the sheet would provide better protection.
I believe it’s important to keep both protection and ventilation in mind. Especially with wood or coated boards, moisture can otherwise cause problems. How do you handle ventilation? Do you think that fully sealed panels are more likely to cause damage?
Tarbi
25 Jul 2015 11:03
HORST41 schrieb:
How do you handle ventilation? Do you think solid panels might cause issues?
This is an important point. Moist air needs to escape; otherwise, there is a risk of mold and material damage. In my opinion, airtight coverings for Kallax units used outdoors can be problematic. Panels with spacers or even ventilation slots are better. I would say a constructive solution is preferable to complete weather protection.
matthewon
25 Jul 2015 11:47
Tarbi schrieb:
More of a constructive solution than full weather protection
Well, why settle for half measures? If you want a shelf for outdoor use, you should either go for fully weatherproof furniture or avoid makeshift solutions altogether. Kallax is actually designed for indoor use – all the effort with cover panels is just a hassle.
In my opinion, anyone experimenting with cover panels here is inviting problems. It’s better to invest properly.
emmaju
25 Jul 2015 13:08
I understand your approach, Jandra, and I actually find it quite reasonable. Kallax is not designed for outdoor use, but some people want to incorporate the look or the level of functionality.
For a project like this, I used plastic panels that are quite resistant to moisture and UV exposure. I fixed them in place with EVA seals between the shelving unit and the panel to prevent standing water on one hand, and to avoid direct contact on the other – this helps with ventilation.
For maintenance: clean regularly with a mild detergent, and depending on the situation, spray with UV protection. So far, I haven’t noticed any mold.
Maybe this helps you a bit?
