ᐅ KALLAX edges worn down from frequent wiping – any paint tips?
Created on: 2 Aug 2023 18:07
Pobachir
I’ve noticed that the edges of my IKEA KALLAX shelf have become visibly worn, especially noticeable after frequent wiping with a damp cloth. The surface seems to be peeling or becoming dull in those areas, which unfortunately doesn’t look very nice anymore.
Has anyone had experience with how to best treat or paint these worn edges to make them more durable and visually appealing again? It’s important for me to find a solution that not only improves the appearance but also protects against further wear.
Are there any specific paints or sealants suitable for the edges of KALLAX shelves that don’t make the surface too glossy or noticeably change its look?
I’m looking forward to your tips, including advice on surface preparation and application. Thanks in advance!
I would fundamentally question the panel structure and the material here before simply applying a paint.
The KALLAX shelving unit consists of chipboard with a melamine or laminate coating. This layer is not designed to be sanded or painted – both can lead to undesirable effects, such as peeling or color changes.
I would view this argument critically at this point. Spray paint can actually reduce adhesion on laminate because the surface is too smooth and not specially pre-treated. Not to mention that the chemical composition of the spray paint must be matched to the material.
I advocate a completely different approach: it is better to refresh the areas with a high-quality laminate adhesive or repair film, or in the worst case, repair with matching edge strips. Painting can create more problems than it solves.
PeoDaniel schrieb:
There are also spray paints that can be applied very finely and thinly
Danial schrieb:
I advocate for a completely different approach: rather refresh the damaged spots using a high-quality laminate adhesive or repair film, or in the worst case, fix them with suitable edge banding.This is indeed a very pragmatic approach and is often overlooked.
Especially for furniture made from low-cost chipboard with a laminate surface, repairing with matching edge bands or film strips is worthwhile, as painting usually does not provide a lasting result.
You can often apply these edge bands using a hot-melt glue gun or an iron, restoring and protecting the original look. I would definitely consider this option before using a paint marker or acrylic paint.
Interesting ideas so far, but I would like to ask: How often do you wipe the shelf with moisture?
The problem could also result from cleaning that is too aggressive or too wet, which could actually damage the laminate layer on the edges.
Apart from that, I think treating it with varnish might not address the root cause.
It would be helpful to first clearly define how the shelf is cared for and handled on a daily basis. Does anyone have experience with IKEA’s recommendations regarding cleaning methods for the KALLAX? Or if there are special care products available?
I’m just asking because maybe simple protection and adjusted cleaning could already help.
Thanks for all your varied input; it’s already very helpful.
Regarding cleaning frequency: The KALLAX is located in the kitchen, so it is wiped down at least 2-3 times a week with a slightly damp microfiber cloth, usually with just water, occasionally with a mild all-purpose cleaner that should be suitable for laminated surfaces.
Edge banding or repair films seem like practical suggestions to me, though I’m unsure if I can match the color exactly to the original.
I will look into laminate adhesives and matching films. I am generally open to using paint – but only if there is truly no loss of quality or unwanted discoloration.
Do you have any recommendations for brands that are especially suitable for such sensitive laminate edges? Or perhaps experience with common products available at hardware stores?
Good morning, Pobachir!
Using the kitchen creates a challenging environment because moisture and temperature fluctuations put extra strain on the material.
From my own experience, I can recommend the following: If you are working with varnish, make sure to use an acrylic or polyurethane varnish that is specified as water-resistant.
I had good results with a similar piece of furniture by first applying a primer designed for plastic surfaces. This helped the varnish adhere better and remain durable for longer.
Regarding the color: My suggestion would be to use a very fine brush and, if needed, a color-matching tinting varnish before sealing, to match the color as closely as possible.
Also, small damages can be concealed with repair wax or a furniture touch-up pen before you apply the varnish.
Good luck!
Good luck!
I would like to summarize and clarify the discussion to identify the most promising approach.
First, it is crucial to accurately assess the condition of the laminate edges: Are the edges chipped laminate, worn paint, or swollen wood underneath?
From a technical perspective, the edges of KALLAX units are often not suitable for sanding because the laminate layer is thin and not load-bearing. However, light sanding with very fine sandpaper to slightly roughen the surface for better adhesion is usually unproblematic.
For coating, specialized synthetic resin paints or two-component (2K) acrylic-polyurethane paints designed for laminate, plastic, and wood are recommended. Alternatively, a repair-appropriate laminate edge band can be used if both appearance and protection are desired.
Please note: All coatings should be matched as closely as possible to the original surface texture and color mix to remain inconspicuous.
For everyday cleaning: Avoid wiping with excess water or harsh cleaners. A dry microfiber cloth, or slightly damp if needed, is optimal.
My recommendation:
1. Lightly sand the edges (fine grit).
2. Clean and dust off the surface.
3. Apply a primer suitable for plastic.
4. Apply thin layers of paint (acrylic or synthetic resin).
5. Allow to dry and, if necessary, seal with a matte finish.
Alternatively, consider edge banding.
Please test this procedure on a small, inconspicuous area first.
My recommendation:
