ᐅ KALLAX edges worn down from frequent wiping – any paint tips?
Created on: 2 Aug 2023 18:07
Pobachir
I’ve noticed that the edges of my IKEA KALLAX shelf have become visibly worn, especially noticeable after frequent wiping with a damp cloth. The surface seems to be peeling or becoming dull in those areas, which unfortunately doesn’t look very nice anymore.
Has anyone had experience with how to best treat or paint these worn edges to make them more durable and visually appealing again? It’s important for me to find a solution that not only improves the appearance but also protects against further wear.
Are there any specific paints or sealants suitable for the edges of KALLAX shelves that don’t make the surface too glossy or noticeably change its look?
I’m looking forward to your tips, including advice on surface preparation and application. Thanks in advance!
Pobachir
3 Aug 2023 11:00
Dilen schrieb:
Could you specify exactly which KALLAX model this is?
I already mentioned it—it’s the white standard KALLAX with laminate.
faso31 schrieb:
How often do you wipe the shelf with a damp cloth?
The answer is also given further up.
I find the arguments for edge banding very interesting, but a practical question: Are there specific manufacturers that offer original color-matched strips, or can you have them custom cut somewhere? And how well do they hold up over time under heavy use like in a kitchen?
Wouldn’t that be much more durable than painting? I’m concerned that with paint, you always run into the problem of new damage forming quickly when the surface is constantly touched and wiped damp.
Elodie
4 Aug 2023 12:27
A small addition from me on the topic of maintenance:
If you want to protect the surface occasionally without much effort, furniture oil or a mild wax can be really valuable.
It acts like an invisible protective layer on the edges. The edge won’t become soft or overly glossy but will still be protected against wear caused by moisture.
You can refresh this layer repeatedly – so you can “maintain” the shelf without having to sand or paint it.
A small tip: don’t apply too much and make sure to wipe the surface well after applying, otherwise it will attract dust 🙂
Danial
5 Aug 2023 08:05
Pobachir schrieb:
Are there specific manufacturers with original-colored strips, or can you have them cut exactly somewhere?
Yes, there are indeed manufacturers of laminate edge bands that offer a wide range of colors.
You can find edge bands for melamine, foil, or real wood designs at hardware stores or online, including brands like "Tesa," "PATFIX," or specialized furniture accessory manufacturers.
Precise cutting is possible, as they can be trimmed quite flexibly with scissors.
However, the edge bands are usually 2-3cm (about 1 inch) wide, so you need to press or iron them on carefully and possibly trim any excess.
Regarding durability in the kitchen: they are very robust if installed properly. A clean surface and firm application are essential!
The advantage: you get an almost like-new edge appearance similar to the original.
The disadvantage: some effort is required for installation and purchase.
