I am considering painting my IKEA Malm furniture myself to give it a personalized look. I have read that the surface is laminated with melamine, which might be challenging.
My question is: Is it really possible to paint these Malm pieces without the paint peeling off or failing to adhere properly? What should I specifically pay attention to when preparing the surface and choosing the paint?
I would appreciate tips on suitable sanding methods, primers, whether there are certain paints or types of finishes that work better, and any other important points to keep in mind when working with Malm furniture.
Thanks in advance!
Thanks in advance!
On painting IKEA Malm furniture:
The furniture is coated with a melamine foil that is very smooth and durable. Applying paint directly without preparation usually leads to adhesion problems.
Therefore, it is important to:
1. Sanding: Roughen the surface using fine sandpaper (grit 180-220) to improve adhesion.
2. Cleaning: Thoroughly remove dust and grease residues after sanding.
3. Priming: Using a special primer designed for smooth surfaces is recommended.
4. Choice of paint: Water-based acrylic paints are well-suited because they are flexible and easy to apply.
5. Intermediate sanding: Lightly sand between paint coats.
6. Drying: Allow sufficient drying time, ideally in a dust-free environment.
Following these steps ensures a durable finish. Without careful preparation, the paint may peel off.
Hello teopo!
Painting Malm furniture is definitely doable, and the results can turn out really great!
Important: Take your time when sanding, and make sure to repair any small dents beforehand. A primer is absolutely invaluable!
I recently painted my own Malm dresser and used acrylic paint from the hardware store. Everything is holding up really well and looks fresher and more modern. 🙂
Good luck, and be sure to show us how it turned out!
