ᐅ Cleaning Malm furniture besides painting – what options are available?
Created on: 7 Feb 2023 08:17
SONKI
SONKI
7 Feb 2023 08:17
I have an IKEA Malm piece of furniture that I would like to clean, but I’m facing the issue that the surface is varnished, and I don’t want to use harsh cleaners.
My specific question is: What are the methods to clean Malm furniture besides completely repainting or refinishing it? I’m particularly interested in how to preserve the existing varnish layer while effectively removing dirt, grease, or light scratches.
Are there any special cleaners or home remedies that are gentle and won’t damage the appearance? Is light sanding advisable, or is it better to fully refinish the surface?
I look forward to your experiences, tips, and advice, preferably including detailed steps and potential pitfalls. Thanks in advance!
retau
7 Feb 2023 08:53
Oh, this is a really interesting topic! 🙂
I once cleaned a Malm bed myself and was careful not to damage the paint finish. It’s important to avoid harsh cleaning agents – something like a mixture of dish soap and water works great for everyday dirt.
If you have minor scratches, there are special furniture polishes or waxes that refresh the surface without much effort and without the need for repainting! That’s fantastic because it saves a lot of time and work!
I’m curious to see what the professionals here will add :-)
FeAndreas1
7 Feb 2023 09:44
Hello SONKI,
Your very good and detailed question is something we can address here. The surface of Malm furniture is usually sealed with a thin melamine resin layer, which is resistant to moisture and some cleaning agents but can be damaged by aggressive substances and mechanical stress.
For cleaning, I generally recommend a mild detergent, for example, a few drops of dish soap in warm water. It is important to use a soft microfiber cloth and avoid scrubbing pads, as they can dull or damage the surface.
Another approach for removing grease or fingerprints is to use isopropanol (rubbing alcohol) in a strongly diluted form. Please test for colorfastness first in an inconspicuous spot!
Regarding whether intermediate sanding is advisable: this only makes sense if you have deeper scratches, as the melamine coating is only a few micrometers thick and is usually sanded through in these areas. In that case, repainting or at least applying a suitable clear coat is recommended.
What does your furniture piece look like? Are there only slight signs of wear or more significant damage? Do you maybe have a specific issue, such as glue residue or something similar?
Espen
7 Feb 2023 09:57
I usually clean Malm furniture with warm water and mild dish soap.
For minor scratches, I recommend furniture polish or a furniture touch-up marker in a matching color.
Sanding should only be done if a complete repainting is planned.
Josefane
7 Feb 2023 10:13
I think it is important to critically consider whether the surface is meant to be cleaned only superficially or if a visual refresh is intended.
FeAndreas1 schrieb:
The surface of Malm furniture is usually sealed with a thin layer of melamine resin...
This information is crucial because it renders many conventional cleaning methods ineffective or even harmful.
Are these pieces of furniture truly painted or are they laminated? This is often confused, and it significantly determines the cleaning options. The topic of intermediate sanding is especially critical here – it often causes more damage than benefit if the material is only laminated.
Can someone confirm the material composition of the furniture?
Jeffon
7 Feb 2023 11:26
In summary: Malm furniture is usually coated with melamine or foil, not traditionally painted. Therefore, cleaning should be done with mild, pH-neutral cleaning agents.
Recommended procedure:
1. Clean the surface with a damp microfiber cloth and soapy water.
2. Remove grease and fingerprints with isopropanol (test first).
3. Do not use abrasive sponges or aggressive cleaners.
4. Treat light scratches if necessary with color-matched furniture markers.
Sanding between coats only makes sense if you want to completely repaint the surface. Otherwise, it can damage the protective film.
When using paint or clear coat, please ensure compatibility.
