ᐅ KALLAX edges worn down from frequent wiping – any paint tips?
Created on: 2 Aug 2023 18:07
PobachirHello everyone,
I’ve noticed that the edges of my IKEA KALLAX shelf have become visibly worn, especially noticeable after frequent wiping with a damp cloth. The surface seems to be peeling or becoming dull in those areas, which unfortunately doesn’t look very nice anymore.
Has anyone had experience with how to best treat or paint these worn edges to make them more durable and visually appealing again? It’s important for me to find a solution that not only improves the appearance but also protects against further wear.
Are there any specific paints or sealants suitable for the edges of KALLAX shelves that don’t make the surface too glossy or noticeably change its look?
I’m looking forward to your tips, including advice on surface preparation and application. Thanks in advance!
Pobachir, your issue is quite common when surfaces are frequently wiped with moisture and the material is not highly durable.
To treat the worn edges, I recommend using a matte water-based acrylic varnish. It is easy to apply, does not soak in too deeply, and provides good protection against further wear. It is important to lightly sand the edges beforehand to ensure better adhesion of the varnish.
One additional tip: If you want to preserve the color as much as possible, get wood touch-up markers in matching shades to conceal small color differences before applying the varnish.
I’d like to address this topic in a bit more detail, as preparation and choosing the right type of paint are crucial for a long-lasting, good result.
First, you should gently sand the edges. I recommend using sandpaper with a grit of 220, which is fine enough not to damage the surface too much but rough enough to ensure good paint adhesion. Be careful not to remove too much material—just roughen up the affected surface.
After sanding, thoroughly remove the dust—ideally with a slightly damp, lint-free cloth to avoid any remaining sanding dust.
Regarding the paint: water-based acrylic paint is generally recommended because it dries quickly and has low odor. However, make sure the paint is specifically suitable for wood or furniture.
An alternative could be a so-called furniture sealer varnish, which applies a bit thicker and therefore offers better protection. It’s important to apply thin coats and let each dry well, as multiple thin layers provide better durability than one thick layer.
If you prefer a non-glossy finish, you might consider a light sealing with matte varnish afterwards.
Pobachir, could you please specify which exact KALLAX model this is (e.g., white, birch, or another color) and whether the edges are already painted or just laminated? This significantly affects the preparation needed.
Thanks in advance for the very helpful tips, JONSON and Dilen!
The shelf is the classic white KALLAX with the laminate-coated surface, like the one IKEA uses. The edges are not brushed, but rather smooth with a thin laminate layer.
Therefore, I suspect that the surface is thinner at the edges or swells and detaches over time due to damp cleaning.
To Dilen’s question: No, the edges are not originally painted; only the laminate layer was factory-applied, as far as I can tell.
Do you think sanding such a laminate edge is even feasible without losing too much material? And if so, how fine should I work to avoid causing further damage?
PeoDaniel2 Aug 2023 19:38Pobachir, thank you for the further clarification!
Since you mentioned a laminate layer, sanding will actually be a bit more challenging. Laminate is a plastic coating that can be easily damaged by excessive sanding, and underneath is either particleboard or MDF, which is very sensitive to sanding.
My recommendation would be to carefully roughen the edges with very fine sandpaper (grit 320 or finer), just enough to smooth out any loose fibers or torn areas, but without removing too much of the laminate. This will prevent unsightly transitions after painting.
Afterwards, you should definitely use special synthetic resin paints that are suitable for laminate and plastic. Many wood paints do not adhere well in this case.
A plastic primer might also help improve adhesion.
There are also spray paints that can be applied very finely and thinly, which could be an option to achieve a smooth surface.
That almost sounds like a small construction project with your KALLAX! 🙂
When I imagine constantly polishing the edges with a damp cloth, without applying anything to the finish in between, it’s clear that the surface will eventually suffer.
I had a similar problem with a comparable shelf and tried using a very fine, matte furniture wax. It creates a light protective film on the surface that doesn’t add shine but protects against further wear.
The advantage is that it’s relatively easy to apply and can be removed without residue—if you later decide to go for a paint or varnish finish.
Maybe you could try waxing it as a temporary solution first? 🙂
