ᐅ IKEA Kallax Shows Stains After Several Years – Should I Repaint or Replace It?
Created on: 19 Oct 2023 08:13
Elonfra
I have an IKEA Kallax shelf unit that I bought about 6 years ago. Over time, some unattractive stains have appeared on the surface, apparently caused by moisture and light wear. The shelf is otherwise still stable and functional, but the appearance bothers me more and more.
Now I’m facing a decision: Should I simply buy a new Kallax, or would it be more sensible to sand it down and repaint it?
Does anyone have experience with painting Kallax or similar IKEA furniture? What type of paint would you recommend to ensure the surface not only looks good but also remains durable? And is the effort really worth it compared to buying a new one?
I look forward to your insights and tips!
BOLUKEO
19 Oct 2023 11:45
I would paint it. Simply sand it down, lightly roughen the surface with 120-grit sandpaper, then apply a primer followed by 2-3 coats of polyurethane paint. Very durable. Saves money compared to buying new.
Elonfra
19 Oct 2023 13:00
Thank you for all the feedback so far.
@andre3, it’s interesting that the melamine coating can’t be freely sanded off. I would have assumed you’d at least need to sand down minimally to the substrate.
Does anyone know of alternatives to painting? For example, there are films or self-adhesive coverings that can be used. Do they adhere well to the surface, and is it possibly less work?
I’m open to practical methods that improve the appearance without being too labor-intensive.
daalessio
19 Oct 2023 13:38
Regarding films: self-adhesive films can be a quick visual solution, but they do not always adhere permanently to melamine, especially on surfaces that are heavily used.
Alternatively, a renovation paint designed for melamine or laminate surfaces would be a good option. These paints adhere well, are quite durable, and usually do not require complete sanding, just roughening the surface.
So if you want to cover up stains without too much effort, this could be worth trying.
Ramon4
19 Oct 2023 14:25
One practical tip: When painting, make sure to use the right materials and tools. For example, a fine sandpaper (grit 180-220) and a good brush or, even better, a paint roller for smooth surfaces.
If you are more experimental, there are also spray paints that apply more evenly and leave fewer brush marks. However, consumption increases, and you will need a well-ventilated space.
karlau
20 Oct 2023 09:17
Elonfra schrieb:
Does anyone know of alternatives to painting? For example, there are films or self-adhesive films that can be used.
Your idea is quite practical. However, self-adhesive films are often not as durable as you might think. Especially around edges, they tend to peel off quickly, which looks worse than stains.
If you want to be safe, only one of these options works: paint or replace entirely. Invest once, then have peace of mind for years. What’s the drawback of a complete replacement?
mauka
20 Oct 2023 10:04
Sure, getting a new Kallax is quick – but hey, DIY is somehow more creative and sustainable! 😊 I also think you could create really cool accents with paint instead of just buying the original again.
If you’re feeling adventurous: maybe don’t paint the whole thing, but color individual compartments? This would give the furniture a modern twist, partly hide the stains, and make it more personal 🙂
