ᐅ KALLAX Unit Removed Due to Water Damage – Is It Still Usable in the Garage?
Created on: 8 Nov 2022 08:32
Casimir
I recently removed a KALLAX shelving unit from my garage because there was water damage. The shelf was exposed to moisture for several days – fortunately, it is now dry, but I’m wondering if the KALLAX can still be usefully used in the garage after such exposure.
My main concern is about stability and durability: How well does the coated wood particleboard material handle moisture? Can it last long-term in a typical garage environment (humid, sometimes cold, temperate), or would it be better to dispose of the shelf and replace it?
Does anyone have experience with how resilient the KALLAX is after water damage? I’m also interested to know if it can be reused without special treatment or repairs, or if it’s better suited as a storage shelf in a dry area like the living room.
Thanks for your input!
kulau
9 Nov 2022 08:04
As an addition:
The scenario you described sounds like a typical case of particleboard coming into short-term contact with moisture. Although the melamine coating protects the surface, the edges and cut areas are often not sealed tightly. Water can quickly penetrate these points.
The thermal conditions (5-12 degrees Celsius (41-54°F)) are relatively unfavorable for quick drying, as cool air holds less moisture. The longer water remains, the greater the damage.
The appearance of warping at the edges indicates early swelling. Here, the stability of the joints is crucial.
If no load-bearing parts are seriously damaged and the compartments still hold their shape, you can continue to use the shelf for light storage purposes. However, I would recommend the following measures:
- Place the shelf on feet or a base that protects it from floor contact and further moisture.
- Dry it thoroughly and allow air circulation.
- Regularly check for new deformations or any signs of odors.
If you are looking for something long-term for the garage that is stable and moisture-resistant, steel or plastic shelves might be more suitable.
What kind of items do you want to store in it? If there is enough space, you could also use a plastic box for added protection.
Repar
9 Nov 2022 08:59
KALLAX hardly tolerates moisture.
Okay for light items and if stored dry.
Otherwise, replace quickly.
Mufato
9 Nov 2022 09:21
I would only continue using the shelf in the garage if you can ensure it will not be exposed to any further moisture. If it appears stable, it can still be used.
Otherwise, it is better to bring it inside the house or replace it.
Charles
9 Nov 2022 10:02
to add to what has already been mentioned: The adhesive in particle boards is particularly sensitive to moisture, as it is usually based on phenol or urea resin. Once moisture penetrates, the board as a whole loses strength.
I recommend checking the shelf carefully at key stress points, especially the joints and edges. If cracks or damage are visible there, it is either temporarily or permanently no longer load-bearing.
If you want to continue using the shelf in the garage, you should definitely isolate it from the floor (for example, with wooden strips), protect it from further moisture, and ensure air circulation.
If stability is more important than cost, you might consider replacing individual damaged shelves.
Also, gently sanding the damaged areas and sealing them can improve durability if you plan to use it long-term.
Casimir
9 Nov 2022 18:17
Thanks for the tip!
Are there universal replacement shelves for KALLAX that can be bought somewhere if I only want to replace certain shelves?
Or is it better to cut complete panels? I’m unsure about how precise the measurements need to be.
What about sealing? Should I just apply clear varnish, or are there special products you would recommend?
Guyju
10 Nov 2022 07:38
Casimir schrieb:
Are there any universal replacement shelves for KALLAX that can be bought somewhere?
Hi Casimir,
There are replacement shelves from IKEA specifically for KALLAX, but they are rarely available individually in retail and are often more expensive than new units. Additionally, they are custom-sized for the KALLAX system.
If you want to cut your own shelves, keep in mind:
- KALLAX typically has a depth of 39 cm (internal dimension about 33–34 cm (13–13.5 inches) depending on the model and edge).
- The thickness of the particle board is about 1.5 cm (0.6 inches).
I would recommend buying MDF boards with waterproof paint or plywood instead of particle board with melamine coating, and have them cut to size.
For sealing: water-based clear lacquer works well. There are also special wood sealants for humid areas that offer additional surface protection and increase durability.
Important: Always seal the edges thoroughly to prevent moisture from entering.
Conclusion: If the shelf is only slightly damaged, replacing it with well-sealed parts is worthwhile. Otherwise, pragmatically replace or repair the whole shelf.
