ᐅ Test of Kallax as an Aquarium Stand in an Older Home – Any Opinions?
Created on: 27 Jun 2024 14:03
Takelu
I am considering using an Ikea Kallax shelf unit as a stand for my aquarium. The aquarium will be placed in an older apartment, and I am mainly concerned about stability, moisture damage, and the overall load-bearing capacity of the furniture. My Kallax has the standard dimensions and is supposed to support an 80cm (31.5 inches) tank holding about 100 liters (26 gallons) of water. Has anyone gained experience with how reliable such a shelf is under the specific conditions of an older building (often uneven floors, possibly higher humidity, old insulation)?
I would like to know if the Kallax is actually stable enough, what modifications might be recommended (reinforcements, moisture protection measures), and if you can suggest any alternatives with better durability.
General opinions and experiences regarding the Kallax as an aquarium stand, especially in older buildings, are welcome so I can properly assess the risk. Thanks in advance!
Nathanaelk28 Jun 2024 09:44I can confirm from personal experience that the Kallax, if left untreated, is quite susceptible to water damage, especially in older buildings with potentially higher humidity levels. My recommendation for a stable, durable solution:
1. Level the floor: Use sturdy small wooden wedges or adjustable furniture feet (for example, from a hardware store) under the shelf legs to ensure a completely flat support surface.
2. Plywood sheet as a base: First, place an 18-20 mm (0.7–0.8 inch) thick plywood sheet in the top shelf compartment. Set the aquarium on this to better distribute the load and relieve the particleboard of the shelf.
3. Sealing: Use a two-component polyurethane wood varnish. It is very resistant to moisture and abrasion. Alternatively, you can apply epoxy resin to the top surface. This protects the plywood and the Kallax shelves from rising moisture.
4. Protect the interior walls: Treat interior surfaces that come into contact with the tank or equipment with epoxy resin or a special wood preservative that is water-repellent.
5. Distance from the wall: Keep the shelf slightly away from the wall to prevent mold growth caused by wall moisture.
6. Equipment: Make sure the filter, CO2 system, and wiring are monitored and free from water accumulation. Insulate cables with rubber mats.
Question: What is your budget for reinforcements? Obviously, cheaper options like waterproof blinds and sealing tape are possible, but I assume you want protection that lasts over the long term.
Takelu schrieb:
My floor is not perfectly levelThere’s the crux of the problem. An uneven floor combined with moderate to high humidity and Ikea furniture as a base cabinet is not the best setup for an expensive aquarium.
Anyone downplaying these risks underestimates the potential for material fatigue caused by even minimal movement and moisture.
But hey, if you insist on using the Kallax, at least reinforce the entire structure yourself, add cross braces, level it perfectly, and seal it thoroughly with paint or lacquer. Otherwise, don’t expect to get any compensation later. 😉
