lucianoba3 Mar 2016 08:17Hello everyone,
I’m currently considering getting a Kallax shelf from IKEA, but I have a question that maybe some of you can answer: Does a Kallax shelf (the standard size 77x77 cm (30x30 inches), depth 39 cm (15 inches)) fit easily into a car without needing to be disassembled for transport?
I have a medium-sized station wagon, but I’m unsure about the height and whether the shelf can be tilted or if it’s too bulky. Has anyone tried this? How did you go about it?
I would appreciate any experiences, even if different vehicle types are mentioned. Thanks!
lucianoba schrieb:
Does a Kallax shelf unit (the standard size 77x77 cm (30x30 inches), depth 39 cm (15 inches)) generally fit into a car easily, so it can be transported without disassembly?Hey,
nice thread starter! I loaded the Kallax into my Golf a few months ago—without taking it apart. I folded the rear seats all the way down and slid the shelf in at a slight angle (depth fitting into the footwell). It went surprisingly well, with some light shifting due to the size, but overall no problem.
Sure, station wagons (estate cars / wagons) might be easier. And yes, you need a bit of care, but you don’t always get a beast like that shelf in pieces 😉
Hello lucianoba,
I recently had the same issue and wanted to transport my Kallax shelf unit as is. Important info upfront: The standard dimensions of 77 cm (30 inches) height and width, and 39 cm (15 inches) depth, are quite bulky for many cars.
If your car has foldable rear seats, there’s a good chance you can at least fit it in diagonally. My advice: Measure the maximum height of your loading space (e.g., trunk plus folded seats). Sometimes the roofline of the vehicle is the limiting factor here.
With some patience and careful maneuvering, it often works, but personally, I believe many people opt for partial disassembly. It’s best to use the included tools to unscrew the frame.
If you want, I can also share tips on how to quickly take the shelf apart and then reassemble it stably.
Best regards!
Best regards!
lucianoba3 Mar 2016 11:05chen67 schrieb:
I folded down the entire back seat and then slid the shelf in at a slight angle... Went surprisingly wellThanks for the tip! Could you possibly say whether you transported the shelf with the opening facing up or down? I ask because I'm concerned that the surfaces might get scratched if it’s placed the wrong way.
